E-Class (W211) 2003-2009
2006 E500 key question
Old Dec 6, 2025 | 03:07 PM
vetal's Avatar
2004 Sprinter
I recently bought a 2006 E500 4matic wagon, did a lot of work on it, a lot still to be done.
I got the car with one key. A few days ago pulled the blade out of the fob and it turns out it is not cut…
what do I do next?
if the fob battery goes low , I am screwed, right?
Old Dec 6, 2025 | 06:20 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Go to dealership with proof of ownership. Order a new mechanical key (it is ordered separate from the key fob; I think mine was ~$80 or so) and the dealership will provide you a replacement mechanical key cut to fit your VIN. Yes, you will need that mechanical key at some point in your ownership. Bring your key fob as their are different mechanical keys depending on which key fob you have. In my case, the mechanical key was required to open the trunk when the mechanism went awry using the key fob. Used the mechanical key one time, and it reset the mechanism for the key fob.
If you do not have a second key fob, bite the bullet and order a second key fob. You can have the dealership delete the missing key fob from the authorization tables in the ECU and CGW (for a significant processing fee) but it is not a requirement unless you suspect a previous owner may try to "borrow" your car. The new key fob will teach itself in to your car in a couple of hours of driving; it can be intermittent driving as the key fob will continue the "teach in" process the next time you drive the car with it.
I have a post or two concerning the DAS3 system used in our cars. FWIW, you have the later version of the key fob; my original 2005 key fob was all black with no chrome.
Old Dec 6, 2025 | 06:36 PM
vetal's Avatar
2004 Sprinter
Thank you very much!
I am not worried about previous owner at all He might be overseas for a while and not from my state
Old Dec 6, 2025 | 06:38 PM
vetal's Avatar
2004 Sprinter
And I can transfer the “ guts” of the fob into a new aftermarket fob shell, right?
The original fob has seen better days
Old Dec 6, 2025 | 08:44 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Yes. Be gentle. I managed to break off the IR diode on the front of the key fob circuit board when I was a bit rough working on it. Keyless Go would work but not in the EIS ignition switch. Used a high-power magnifying loupe to identify the proper orientation of the IR diode and soldered it back onto the board. Just a "heads up" for ya.
https://mbworld.org/forums/w211-amg/...ob-repair.html
