E-Class (W211) 2003-2009
No heat
Old Dec 30, 2025 | 01:40 AM
popdaddy1's Avatar
2008 e350
No heat
Have 2008 e350 sedan with very little Heat. Control valve was change this summer but still little heat.my question is can the control valve be Bypass for now? If so how
Old Dec 30, 2025 | 09:50 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Sure it can be bypassed but then you get max heat all the time.
Remove wiper blades.
Dismount yaw sensor and move to one side.
Remove plastic cowling.
Remove wiper mechanism.
Remove heater control valve.
Install short hose from coolant supply line to one of the heater core connections.
Install another short hose from other heater core connection to the coolant return line using a brass nipple.
Reinstall wiper mechanism
Reinstall cowling.
Reinstall yaw sensor.
Reinstall wiper blades
After the above, you still need to figure out what is up with the heater control valve...and perform the work all over again.
If the heater control valve is OEM dealer purchased, where I am at there is a 2-year warranty on parts. If not a parts issue, you need to look at the HVAC system.
