E-Class (W211) 2003-2009
W211 E350 2007 secondary air injection pump problem
Old Jan 17, 2026 | 03:25 PM
MSW140's Avatar
After my car's ECU failed, I replaced it with a 2008 model unit. Subsequently, I noticed that the fuse for the Secondary Air Injection (SAI) pump was blown. I replaced the fuse, but it blew again immediately upon operation. However, when I disconnected the electrical connector from the pump, the fuse remained intact.
Is this issue caused by a software/programming error in the new ECU, or is it a mechanical/electrical failure within the pump itself?
Furthermore, do you recommend repairing the pump or replacing it entirely?
I am considering dismantling and inspecting the pump, or performing a resistance test as demonstrated in the video.
Old Jan 19, 2026 | 09:19 AM
Heguli's Avatar
2006 E280
Most likely problme lies in the pump, but check the wiring, too. Easiest way to fix the issue is to replace the pump.
