E-Class (W211) 2003-2009
W211 Retrofit: Dead Facelift Cluster after 2 days. Can I build a "Hybrid" from two un
Old Feb 7, 2026 | 11:15 AM
kristiyan's Avatar
E200 CDI w211 and ML320 CDI w164
Hi everyone,
I’m looking for some technical advice on a W211 cluster retrofit that went south. My car is a Pre-Facelift (Pre-FL), and I upgraded it to a Facelift (FL) cluster. I made the FL unit "Virgin" via OBD, coded it with STAR Diagnosis (DAS), and it worked perfectly for two full days—AMG menu, needles, everything was spot on.
The Issue: On the third day, the new cluster went completely dead. Black screen, no needle movement, nothing. When it's plugged in, it seems to be "clogging" the Interior CAN Bus:
  • The Climate Control display goes very dim (emergency mode).
  • Parktronic (PTS) stops working.
  • STAR Diagnosis shows "No communication with ICM."
As soon as I plug my original Pre-FL cluster back in, everything in the car works perfectly again.
My Questions:
  1. Can I build a "Hybrid" unit? Is it possible to use my working Pre-FL PCB but transfer the software/firmware from the dead FL unit? I really want to keep the FL software features (AMG menu, updated graphics).
  2. Hardware Swap: Can I swap specific chips (Processor, EEPROM) from the dead FL board to the Pre-FL board, or are the PCB architectures too different to make this work?
  3. Did I kill it? Is it possible that the OBD "Virgin" process or coding caused a delayed failure, even though it worked fine for 48 hours? Or does this sound like a hardware component (like the CAN Transceiver or Voltage Regulator) just gave up?
  4. Repairing the FL board: If the cluster is blocking the CAN bus, what’s the most likely culprit? Is it worth trying to resolder/replace the CAN transceiver chip?
I really want to keep the Facelift look and the AMG features. Has anyone successfully managed to marry parts from these two different generations of clusters?
Thanks in advance for any insight!
