E-Class (W211) 2003-2009
TPMS option 475
Old Apr 19, 2026 | 09:01 PM
gogydm's Avatar
08 E350
TPMS option 475
After seeing
this video I decided to activate this option so I can see the pressures at all times. As you probably know, all 2008 and up have this as standard, some older models probably have it too. It is installed as code 470 if you were to look up the options you have on your car through the VIN.
Here is where it becomes tricky. I changed the option as in the video and I got the pressures to display on my gauge cluster the first time I drove the car with this enabled. Since then, it has gone back to just showing an option to reset TPMS and no pressure values. I can still see the individual pressures with Xentry and the value hasn't reset to 470. I am sure there is something I need to change in the gauge cluster coding, just not sure what. Can someone help me out? Thanks.
Old May 1, 2026 | 01:40 PM
gogydm's Avatar
08 E350
Anybody with this option installed stock willing to look through their cluster programming?
