Intermittent key issues
When it stopped working first, i replaced the battery quickly and it worked for a few minutes while i drove to work from the parts shop, when i got out again and tried to lock it, it didnt work. Went inside for a few minutes and when i got back out again it worked all of a sudden, thats when i checked the fuses. Google was no help, it was either the key didnt work in the cylinder or the lock buttons didnt work. Is there any troubleshooting i can do? The key is only about a year old and the old battery only a few months at this point.
If you have a spare key, try that.
Perform the Phone Camera Test
Switch your smartphone camera on and point it directly at the tip of your Mercedes key.
Press any button on the key.
Look at your phone screen; you should see a bright purple/white flash coming from the key's infrared lens. If you don't see it, the key is not transmitting
Also ensure your main and aux batteries are putting out correct voltage.
