E500 Airmatic problem
Because both front and rear are dropping I assumed that the culprit was either the valve block or compressor so I went ahead and swapped those out with brand new units. The car now raises at least (it wasn't before so I think that the compressor actually blew
under the pressure of having to work so hard before) so I don't regret replacing that compressor. Unfortunately though, whilst the car now raises as it should (the whole car), the right side drops after about 1/2hr to 1hr. Left remains fine.
I ended up uploading results I got from my scanner to an ai and it says that the results suggest that the right front strut is leaking. Thats fine and all but my question is so why does the right back also go down?
Ive attached the scanner results that I got with the care running.
Please Help!
GL.
R,
2Merks
