E-Class (W211) 2003-2009
2009 E350 Troubleshooting
Old Yesterday | 02:17 PM
bigbluebenz's Avatar
2009 E350 Wagon, 1990 Volvo 240
Question 2009 E350 Troubleshooting
I recently purchased a misfiring E350 wagon that I believe is cool enough to be worth saving, but I need some help narrowing down the possibilities.
When I purchased the car it had a handful of misfire codes including P0300, P0301, P0302, P0305. A PCV refresh smoothed it out, but cylinder 2 still has a consistent misfire and car continues to throw the code P0302.
  • First thing I did was check compression, as I knew there was decent likelihood that I had a valve issue. All six cylinders came back in the 150-160 psi range.
  • I also popped off the hall sensors to see if the timing looked alright, all timing marks were perfectly centered in the holes.
  • Next I swapped around spark plugs and coils, the misfire remained at cylinder 2.
  • I used a iCarsoft scan tool to watch the misfire counter and noticed that the misfires count up between 0-2000rpm and then above 2000 rpm they stop.
According to the scan tool the intake manifold pressure is reading 6.53 psi, which I'm thinking indicates a vacuum leak somewhere. I tried spraying brake cleaner around the intake, but did not notice any rpm changes. I have read that these intake manifolds have issues, but I'm not sure what the normal failure modes are. Should I try to track down a vacuum leak or just go for it and replace the whole intake manifold? I'm trying to think of a scenario where only one cylinder misfires consistently because of the manifold and I am having trouble.
Any thoughts are appreciated!
Old Yesterday | 07:25 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Read post #7...I believe this will help sort you out..GL
R,
2Merks
https://mbworld.org/forums/e-class-w...ode-p0302.html
