E-Class (W211) 2003-2009
Delayed Shutdown
Old Feb 14, 2005 | 02:45 PM
khaug's Avatar
'05 E320 CDI, '07 VW Touareg V10 TDI, 2007 Porsche GT3
Delayed Shutdown
Hi all.
When I shut off the engine in my car and remove the key, there is a several-second delay before the audio and nav systems go off. Is this a feature, or do I have trouble developing?
Thanks. Happy Valentine's day.
Old Feb 14, 2005 | 04:12 PM
lorinserbenz's Avatar
none
Radio stays on till you open a door, the windows remain energized too.
Old Feb 14, 2005 | 06:00 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
I really like that feature..
Old Feb 14, 2005 | 06:40 PM
Barry45RPM's Avatar
2015 ML 350
The DRIVERS door. Unlike the GM cars which cut power if any door is opened.
Old Feb 14, 2005 | 10:08 PM
cdiken's Avatar
2005 Carlsson CD32 E320 CDI Inline-6
I wish the ENGINE would have a 3-minute delayed shutdown...
shows respect for the turbocharger.
Old Feb 14, 2005 | 11:07 PM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
On my '03: correct as to the windows, incorrect as to the radio. The radio shuts down as soon as I remove the key, whether the door is open or closed. My car doesn't have nav or COMAND, which might explain the discrepancy.
Old Feb 15, 2005 | 12:09 AM
Barry45RPM's Avatar
2015 ML 350
Ahhhh, the mystical, magical '03s.
Old Feb 15, 2005 | 10:27 AM
TPAbnz's Avatar
2017 E300W
I checked on my way home from the office last night. Radio/Command stays on after the engine is shut off. Everything turns off when the key is removed from the ignition.
Old Feb 15, 2005 | 10:30 AM
alewifebp's Avatar
2014 BMW 550i
2004 model, radio turns off when the key is removed. But, I can easily turn it back on if I desire after the key is out. I actually wish it did not do this, as it makes cleaning the COMAND unit difficult.
Old Feb 15, 2005 | 10:35 AM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Same here. However, the power windows still work until you open the driver's door.
Steve
Old Feb 15, 2005 | 11:35 AM
saffrontiger's Avatar
W211 2005 CDI, X166 2013 350 BT, 997.1 2008 C4S
Sorry I don't follow. Is there something I'm missing when I "power" down my CDI? Thanks
Old Feb 15, 2005 | 02:21 PM
ATS's Avatar
ATS
I have a 2004 and it used to turn off when the key was removed. Now I have a 2004 (still!) and a 2005 Command unit and it only turns off a couple secs after I open the door. I like it a lot as when I turn off the car I still like to have my music on until I get out of the car which can sometimes take a couple minutes if I am getting stuff in my pockets, etc etc..
Old Feb 15, 2005 | 02:46 PM
moa4r's Avatar
S4
'03 model, radio turns off when you remove the key..."easy entry" stuff starts moving when you remove the key also. I noticed the car stereo staying on until the door is opened on a GM loaner I had, kind of liek that feature.
porsche cars have the radio fade out when you remove the key and open the door, thats the best IMO.
Old Feb 15, 2005 | 02:48 PM
moa4r's Avatar
S4
some people say you should leave turbo charged cars running (turbo cooling) for a few mins before shutting down so you don't leave hot oil in the turbos. I have no idea if this is recommended/neccessary for the diesel.
Old Feb 15, 2005 | 02:55 PM
cdiken's Avatar
Turbocharged cars....
Most turbo damage happens at shutdown, turbo and bearings are very hot, and oil "cooks" on the bearings.
Running a turbocharged vehicle at idle after driving, typically for 3 minutes, is recommended to circulate oil throught turbo bearings to cool the unit.
With a diesel engine and Mobil 1 oil, this concern is reduced and not mentioned in the MB Manual, but I still observe it.
FROM HOLSET TURBO WEBSITE:
http://www.holset.co.uk/files/4_3_5-...procedures.php
Shut Down
Before shutting your engine down, let the turbocharger cool down. When an engine runs at maximum power/high torque, the turbocharger is operating at very high temperatures and speeds. Hot shut down can cause reduced service life which is avoidable by a minute or two of idling. Most mobile equipment applications include an adequate cooling period during parking or mooring procedures.
See hot shutdown graph.
Allow your engine to idle for 1-5 minutes to allow the high temperatures and speed to reduce and so prolong the life of your turbocharger.
MotorHaven.com :: Diesel Turbo Lifesaver :: GM Duramax
Help increase the life of your diesel.
Failure to care for your diesel truck's turbo can cause prematurely fail. For proper turbo care you should all the truck to idle for a few minutes to allow the turbo-charger to cool down. This is especially important for vehicles modified for additional power and heavy towing.
The problem is idle time isn't convenient. No one wants to wait on their truck, especially if they are in a hurry.
The Diesel Turbo Lifesaver is the answer! A simple, no wire cutting installation inside the vehicle (instead of under the hood) and the truck can now automatically idle and shutdown itself without the ignition key. The steering column stays locked to prevent theft.
GM Duramax
Sort by: SKU Product Price Sort direction Default
Product ID: BA-GMD1/15
2000 - 2004 GM Duramax Diesel Turbo Lifesaver
See details 2000 - 2004 GM Duramax Diesel Turbo Lifesaver
# Features Easy plug-in installation with no wire cutting.
# In cab installation (not under the hood!)
# Selectable cool down times up to 15 minutes.
# Cancel cool down with switch or by depressing brake pedal.
# Anti-theft mode: prevent the vehicle from being s...
Market price: $274.99
Our price: $235.99, save 14%
Quantity
DOES ANYONE MARKET THIS PRODUCT FOR MB DIESELS?
Old Feb 15, 2005 | 04:52 PM
This is exactly why I really like this forum so much. The more I read, the more I learn. I never knew about turbo "cool-down". Although it's not mentioned in the w211 manual, I will try to observe this more often. Thanks again!
Jay
