e550 air suspension malfunction
Has anyone had a problem with air suspension. I had an issue about a month a go with a bent rim. A few days after that the malfunction light came on and it rode rough. The dealer said the strut was not receiving air and needed replacing. I put a new rim on to replace the bent one and checked all the lines and sensors to the strut. After that everything was fine without having to replace the strut. Then yesterday the malfunction light came on again and is riding rough again. I took the wheel off this morning to play with it but to no avail.. I can't see this being a full strut issue!
Any suggestions???
Any suggestions???
Any suggestions???
Any suggestions???
Do you mean it runs rough but the suspension level is fine? Sounds pretty odd except if the shocks had some serious issues. Haven't heard about this kind of an issue with the shocks.
If the air spring does not have any air, then that strut stands on the rubber buffer and the ride certainly would be rough. But you would see it from the corner of the car being really low (if not more than one corner).
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Aside from the fact that this is the W212 forum, and the poster is posting on the wrong forum, could everybody who has technical questions PLEASE LIST THE YEAR of the vehicle in question.
Sometimes people don't even mention the model
It's very easy to put the details of your vehicle in your avatar thru the User CP.
no its a 212.. 2007e550.. the level is fine but the suspension is in limp mode and rides rough. watched the dealer read the codes and said airmatic valve unit on left front strut. they say i need to replace the whole strut to fix this... $1500 part!!
$1500 sounds too high for the part, was that including the labour to change it?
There are refurbished struts available too (not from MB).
