E350/E550 coupe in the snow! Any opinions?
But... after hours of hardwork yesterday... washing, waxing and polishing, the car whispered to me, not to be driven today...
Yesterday was a very clear and pretty much Spring weather, 51F..
So I obey....
Two weeks ago, I happend to drive this car on the highway with fully covered Snow... The 4Matic handling was superb in this kind of conditon. Few times the Yellow Triangle flashes but I could not tell the difference that the system was working. Drove like normal. But after cleaning her the whole day yesterday, I don't think I have the courage to torture her... maybe next time....
My experience is based on my primary snow car, an '87 300TD, and the other car which I generally don't drive in snow, an 01 E55. Both are RWD. I figure the E55 is similar to an E550 power-wise and in snow. The 87 has 4 studded nokian hakkapeliitta 2's, and the tires make it fantastic in snow - climbs snow-covered hills that a friend's audi quattro (with summer tires) can't get up and it turns / stops faster than any AWD car with with all-seasons. The E55 isn't as bad in snow as i'd expect, it's actually comparable to the 87 on it's all seasons despite the E55's 275 wide rear tires (both pretty bad though).
Now we get into the theories (and the reasoning behind why i'm hoping an E550 RWD will be ok for me). I feel there are two types of driving in snow - getting going and going fast. For getting going, AWD is clearly better than 2WD. In practice, this is only an issue on hills and in my experience i've never actually not been able to get up a hill in my snow car when it has the right tires on it - though i've had to put weight in the back, get speed up, fishtail the whole way up, etc a couple of times. So have any of you been unable to get up a hill in your E550 RWD with snows? Can you turn the traction control off enough to allow the snow tires to spin/dig through the snow and get down to firmer ground?
The other type of driving in snow doesn't have anything to do with getting going, it's about how fast you can safely go. I would imagine that this is almost entirely the tires and very little with the number of wheels getting power. However, i keep on hearing folks say that the 4matic's feel way more stable than the RWD cars. Is that because the RWD cars come with summer tires that are wider in the rear, and therefore they really are worse (but it can be fixed)? or is it because people don't like the feel of the rear end sliding a bit when under acceleration (understandable, but different than not being able to control direction and stop)?
btw - my rec on best snow tire (if you don't mind a little squishy on dry roads) is a Nokian Hakkapeliitta. the studs may be overkill in most spots, but the tires turn my rwd car into a tank and i can literally turn rings around any awd car or suv with esp etc. Mercedes has a recommended size for winter tires for each car model (for instance, my 01 E55 is taken from a 18in wheel and 275 rear tire down to a 17 wheel and 245 rear tire). Also, if you google "miata tire size" there's a guy on a miata forum that made a tire circumference calculator that you can use to match the rolling circumference of your winter tires to your stock tires.
I respect and understand your thought about driving the car you bought for enjoyment. It makes sense. If you use the E550, even with snows as a DD, you should be prepared for a few days a year where you might just have to say -- not today :-)
I think now they make a new tire WS70, so you'll have to read which is better. My blizacs are going in the 3rd winter now and they are not even half used up. One thing to watch out is that the top speed on the WS60 is only 110 mph. I'm fine with that and I did not want a performance winter tire because I was looking for maximum winter snow/ice/extreme cold weather handling.
However, I should say, that in mildly cold weather above ~35 deg F, the car does not stop as well on dry pavement. If the weather gets really warm (like in spring or early winter) such as 55-60F, you have to drive extra careful as the car cannot handle emergency maneuvers. My VR4 started fishtailing when I changed lanes suddenly in warm weather.
Of course, I use dedicated max performance summer tires on my cars for the other 3 seasons.
-Mike-
2008 E320 Bluetec
1995 Mitsubishi 3000GT VR4 - SOLD
Chicago Area
