Sponsored by: CARiD
attention assist
Old Dec 30, 2009 | 09:06 AM
mg-E550's Avatar
2010 E550 4matic, 2008 MDX, 2011 335i Vert
attention assist
It works!! Very late drive from PA home to NY. Suffice it to say I took its advice and got some coffee. If it only made coffee too. The "thats really cool" factor sort of woke me up enough though. Like I suspect many others I had been unsuccessful in tricking it to go off.
Old Dec 30, 2009 | 09:11 AM
highroller550's Avatar
2010 e550 coupe , 2010 ML550
the beep is not alerting at all. i just think its way 2-hyped up then what it really does.
Old Dec 30, 2009 | 09:26 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Very interested to hear about this Feature actually, as to whether it's marketing gimmickery or really works.
The beep is light? If a car was gonna wake me up, it would need a LOUD beep, and something to just jolt me to alertness.
What were you guys doing when it went off, were you actually dozing off, i.e was it accurate?
Old Dec 30, 2009 | 09:30 AM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
How does it work. I was driving from Atlantic City late at night and was trying to make it work just to fool around the system - no response....
Do you actually have to close your eyes ? In what moment it knows you are tired ????
Thanks..
Old Dec 30, 2009 | 09:37 AM
mg-E550's Avatar
Highroller makes a good point about the beep being light. It was enough to get my attention but I would have definitely expected something much louder. Not sure if my eyes closed to be honest but I was defintely badly zoned out and pretty close to nodding off if I hadn't actually. I would say as a safety feature it's not an end all be all but it dovetails nicely with distronic and lane departure on drives like that one.
Old Dec 30, 2009 | 09:39 AM
RickP330's Avatar
2019 GLA 250 - I am in purgatory right now...
I think it looks at steering inputs, speed and time behind the wheel. A gradual slowing followed by sharp course corrections after more then like an hour I think gets it's attention. I read an article about it a long time ago, but it seems pretty cool.
RP
Old Dec 30, 2009 | 09:45 AM
RP
if you actually try to make go off it wont. i tried several times and failed. the 2 times it went off for me were 1, i did a sudden sharp lane change, so i guess it took it as swerving, 2 i was all up night and had to drive 1 hour home and i was getting really tired and it went off, i think maybe i was accelerating then going slow then accelerating , just trying to stay awake. i wasn't swerving or anything . the point is the dealer made it sound like its this state of the art system that will wow you. it doesn't and actually if you do probably fall asleep that little beep wont wake you
Old Dec 30, 2009 | 09:54 AM
emilner's Avatar
S560
It notices change in behavior, not swerving. It samples your drving characteristics for 20 minutes at highway speed (I forget the minimum speed) and then waits for telltale signs of a person getting drousy. According to MB a person normally makes constant small corrections to keep a car in a lane. When you get drousy you typically make less corrections but they get larger as you are no longer paying close attention. If you are a driver who normally makes few but large corrections the car will sample that and look for a deviation from that model.
If you want to test it, you need to drive normally and then act drousy.
Highroller- its sounds as if it worked perfectly for you- You could not make it go off while trying but when you were actually tired it DID. Sounds like a great testamonial to me...
Old Dec 30, 2009 | 10:01 AM
i guess you make sense. looking at it now. it worked like its suppose to.
Old Dec 30, 2009 | 10:34 AM
mg-E550's Avatar
Yes according to manual it looks at 70 different variables. I had distronic on for probably 30 or 40 min straight so even works well without analyzing my accelerator/ brake inputs. I thought Lexus was developing something that analized respiration and eye movement although this system does not.
Old Dec 30, 2009 | 10:51 AM
Rowrbazzle's Avatar
2010 E350
It went off for me a few times on a recent trip - and it was accurate. I know I was getting sleepy and the beep actually did alert me. I knew there was a rest stop 30 minutes ahead so I kept going and it continued to alert me every few minutes or so. I assume my behavior was still indicating drowsiness.
The closest thing to an error in the system wasn't really an error. At one point a car started to swerve into my lane causing me to jerk and speed up to get away. I expected it would set off the system, being as it had already gone off, and it did.
It's never gone off when I wasn't actually sleepy. I don't think it's supposed to wake you up if you actually fall asleep, but to alert you before you get to that point. I wasn't tired enough to actually zonk out, but I was definitely on my way. I'm pleased with the system.
Old Dec 30, 2009 | 11:05 AM
pappilo's Avatar
Airforce 1
It went off on my trip back from picking the car up from the dealer. I wasnt sleepy but I made a sudden swerve back to my lane as I was veering off course because I was messing with the sat nav on my phone.
Old Dec 30, 2009 | 11:21 AM
mg-E550's Avatar
That makes sense- symptoms of distracted driving should be almost identical to those of drowsy driving. (not criticizing you- I am no better)
Old Dec 30, 2009 | 01:06 PM
MBNUT1's Avatar
2010 E350 4Matic
I could have used this on my trip back home last week. I had stopped and got lunch after driving about a 100 miles and got the post lunch drowsies. I noticed myself starting to jerk the wheel as I caught myself drifting toward the left lane. I like the fact that it sounds like it isn't too loud. They are probably afraid of creating a bigger problem by startling you and causing you to overreact.
Old Dec 30, 2009 | 02:26 PM
303E550's Avatar
2020 G63
Mine alerted during a long drive while I wasn't sleepy. I just shifted in my seat and the alert came up. I wonder if it detects seat movement as well...
Old Dec 30, 2009 | 06:03 PM
part of the 70 things it monitors is also the way you are seated
Old Dec 30, 2009 | 07:07 PM
K-A's Avatar
K-A
This is an amazing system. One of the biggest selling points, if not *the* biggest selling point to me personally for a 212.
Sucks the beep isn't too loud, I'd assume they don't want to startle you, but I would prefer something that would slap you awake per-se, like a relatively loud-enough beep, and maybe some steering-wheel vibration.
I drive a lot (not in my E however), and have started dozing off at the wheel way more times than I care to think about, the attention assist would really come in handy for me.
Old Dec 31, 2009 | 01:05 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
steering wheel vibration kicks in with the lane assist system fyi
Old Dec 31, 2009 | 02:26 PM
jumper4000's Avatar
E350 Sedan, P2, Driver's Assist, Panorama roof
For me, it went off a few times on my drive to Vegas. I wasn't tired or drowsy or anything, but we were watching a movie - Hangover, that movie is FUNNYYYYY!
About the beep - I don't think any of the beeps in this car are loud enough. The alarm beep, the break assist beep, the lane keeping assist beep, and all the other beeps should be a few decibels louder... I wonder if there's anyway to turn them all up a notch?
Old Dec 31, 2009 | 02:43 PM
mg-E550's Avatar
HOw did you get it to play a movie while driving? Is there an override?
Old Dec 31, 2009 | 03:51 PM
jumper4000's Avatar
We were watching it on my laptop, but I believe there's a hardware mod.
Old Jan 1, 2010 | 11:48 AM
petee1997's Avatar
...24 GLE53
Watching a movie? There is no system to protect against irresponsibility except the removal of your driving priviledge.
Old Jan 1, 2010 | 01:58 PM
aeggroup's Avatar
Originally Posted by petee1997
Watching a movie? There is no system to protect against stupidity except the removal of your driving priviledge.
Who said driver was watching it ?
Old Jan 1, 2010 | 02:33 PM
MBNUT1's Avatar
2010 E350 4Matic
Why would lane assist activate if the driver wasn't?
Old Jan 1, 2010 | 08:05 PM
petee1997's Avatar
...24 GLE53
[quote=jumper4000;3876556]For me, it went off a few times on my drive to Vegas. I wasn't tired or drowsy or anything, but we were watching a movie - Hangover, that movie is FUNNYYYYY!
About the beep - I don't think any of the beeps in this car are loud enough. The alarm beep, the break assist beep, the lane keeping assist beep, and all the other beeps should be a few decibels louder... I wonder if there's anyway to turn them all up a notch?[/quote
" Who said driver was watching it?"
We implies the driver was watching TV, otherwise you would use the term "they were watching TV" . Maybe I misunderstood your post and you can clarify it for me.
