Sponsored by: CARiD
UMI for 212
Old Jan 8, 2010 | 02:30 PM
tchracing's Avatar
2017 E350e PlugIn Hybrid / W213
UMI for 212
Hi
Has anyone installed a UMI set (universal media interface with Navi) into a W212 with Audio 20 ?
If so, what part number is used?
I tried to fit the W-204 UMI set in my W-212, but i couldnt get the Navi to work in the center radio-display on the dash. I did however got the Navi to work and showing the current roads i am driving at, in the centerdisplay on the instrumentcluster.
When i activate the Navi, the screen just gets black, sometimes it can flash for a second and i can see signs of the navi-text. But just for a split second. But then it gets black imediatly.....
All other functions like radio and systemsettings are working in the radio-display like they did before i installed the UMI.
I can also use my Iphone/Ipod by using the buttons on the steering wheel and play MP3 songs, and it is also available in the instrumentcluster.
So does anyone knows when the UMI set for 212 is available? Or if it is somekind of softwareupdate available for the 204 UMI so i can use it on my 212?
Regards
Tom
Old Jan 8, 2010 | 03:38 PM
Diesel Benz's Avatar
I assume you are not from the US (you might consider indicating your location at your profile), in this case you would probably get more help here:
http://www.mbclub.co.uk/forums/elect...tion-20-a.html
Old Jan 8, 2010 | 05:08 PM
tchracing's Avatar
Thank you, i will check with them. Hopefully it will work out then.
BTW sorry i forgot..., good advice to indicate my location. now i have done it..
Tom
Norway
