Tilt Down mirror
Since it appears to be on demand, so to speak, I set it. Now it happens every time I put the car in reverse.
Anyone using this feature or had any experience with it?
Can it be turned off? e-mailed MBUSA, but no response yet.
Really don't like tilt down mirrors as I do a lot of backing up, but never into a parking space or to parallel park. Well, maybe once every 4-5 years. Also, with the rear view camera I can see to back up fine.
Seems it places a lot of wear on the mirror motor.
Thanks.
GL.
I did use the set up procedure and then hit the memory button and then programmed the tilt down. Now it does not move since I am the only one who drives the car.
Thanks.
Thanks for the help from all of you. I think I have it solved as far as not changing from my mirror settings, but was hoping to be able to "disable" it as you can with several other features of the car.
Thanks.
If the last push of the mirror select button was the driver's side mirror the tilt down will be deactivated. This is even though the light is out and the mirror will not adjust.
BTW, I go to the MBUSA owner's website, e-mail them my questions and they usually call me with a response. Could call, but e-mail gives them time to research the questions before calling.
