Sponsored by: CARiD
Closing trunk with Smartkey or button in door
Old Apr 15, 2010 | 04:02 PM
volfan615's Avatar
2021 GLE 350
I can use the Smartkey or the button in the door to open the trunk lid with no problems but when I try to close it the same way it doesn't work. I hear a clicking noise and that's it. Is there a trick to it or is something wrong?
Old Apr 15, 2010 | 04:26 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
The smart key only opens the trunk, not close it. . Unless u have the trunk closer option, you will have to manually close it yourself...
Old Apr 15, 2010 | 04:32 PM
volfan615's Avatar
2021 GLE 350
I have the trunk closer option. The button on the truck lid works but the smartkey or drive door button don't.
Old Apr 15, 2010 | 05:12 PM
RNBRAD's Avatar
W211 E320 & W212 E550
Your probably not holding the door button until it closes. You can't just push it to close it like you do when you open it, you have to push and hold till it closes.
Old Apr 15, 2010 | 07:06 PM
rt1688's Avatar
2010 e-class w212
You can only close the trunk with the door button but you cannot close the trunk with your remote.
Old Apr 15, 2010 | 10:01 PM
mg-E550's Avatar
2010 E550 4matic, 2008 MDX, 2011 335i Vert
door button works for opening and closing trunk. Key fob cant close the trunk.
Old Apr 16, 2010 | 03:04 PM
OAG's Avatar
OAG
E350 LUX 4M P2 D+
You have to depress and hold the door button to close the trunk. The remote or smart key will not close the trunk. Took me a few days to find out the trunk has a button on the underside of the trunk lid just above the license plate that will open the trunk (if the smart key is close). This is a very interesting car and not all stuff works as I think it should (but then I did not design it).
Old Sep 29, 2024 | 07:44 PM
Raski's Avatar
You have to use Vediamo or DTS Monaco and activate closing with button on key or driver door
