Old 06-12-2015, 07:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Interior rattles, noises and/or creaking sounds?
Rating: Thread Rating: 2 votes, 3.00 average.
Old 04-16-2012, 02:12 PM
  #101
thekurgan's Avatar
E350 BT
I experienced the wind noise, from the driver's side, but I applied some Krytox 205 to the door seal and it hasn't returned. The dash rattle comes and goes, I cannot figure that one out; just poor materials and agree, my BMWs had far fewer rattles and creaks.
Old 04-16-2012, 04:05 PM
  #102
ttoE550's Avatar
2015 GL450
I have a dash rattle too. Try this: When it comes back, pinch together the top and bottom of the dash just behind the top of the steering wheel. (The part of the dash that shields the IC from the sun.) In my car, the rattle will not stop if I press just the top or just the bottom - I have to pinch them together. I will let the dealer fix next time I take the car in. Meantime I might ghetto it by putting a binder clip on it (just kidding!).
Old 04-16-2012, 04:26 PM
  #103
thekurgan's Avatar
E350 BT
THANKS! I haven't thought of that as it looked like one piece. Funny thing in this car, sounds bounce around, making it difficult to pinpoint! I know the steering paddles rattle and so does the dimmer rheostat. On the door, all the seat control buttons can rattle, but usually only in the cold.
Old 04-16-2012, 11:35 PM
  #104
Kar don's Avatar
Mercedes-Benz
i have a brand new bluetec with a rattle in the back of the car, sounds like the rear decklid. Anyone successfully have this fixed?
Old 04-17-2012, 01:46 AM
  #105
thekurgan's Avatar
E350 BT
I found my rear rattle to be the panel topmost rear of the headliner.
Old 10-18-2012, 03:56 PM
  #106
The996's Avatar
07 E63
Got a little rattle in the driver side gauges. When I press on the plastic on the screen, it goes away. Need to find a way to fix this asap.
Old 11-16-2012, 11:08 AM
  #107
Arrie's Avatar
The first cold day and a new very bad rattle starts at the rear of the car. It is coming from the rear deck where the speakers are mounted. Tapping on this flimsy deck produces very bad rattling noise.
Anybody have instructions of how to remove the deck? Would like to have a look myself as this could be very easy to fix.
Old 11-17-2012, 11:24 AM
  #108
thekurgan's Avatar
E350 BT
The rear plastic piece is easily removed, just be careful not to break any of the tabs. You may have a wire or connector loose beneath, which may be seen from the trunk but you may have to lie upside down to view anything.
Old 11-18-2012, 08:48 PM
  #109
Arrie's Avatar
How do you easily remove the plastic part?
Old 11-18-2012, 10:17 PM
  #110
thekurgan's Avatar
E350 BT
I'll pry mine up tomorrow morning and snap a pic, I carefully lifted from the headrest side, small snap clips hold it in.
Old 11-21-2012, 09:50 AM
  #111
thekurgan's Avatar
E350 BT
I have a photo, it's on my phone, I've just been travelling for the holidays. I'll see if I can post it today sometime.
Old 11-21-2012, 10:25 AM
  #112
Arrie's Avatar
Thanks!
I'll be taking mine up as soon as I see the photo.
Old 11-22-2012, 01:36 PM
  #113
thekurgan's Avatar
E350 BT
Thanks!
Here you go, Arrie. As you can see from just under the panel, there are plastic stubs. They click FIRMLY into place, so if yours is loose, you could be hearing the rattle. These tabs are dispersed all around the panel. I found mine was loose in the rear.
I am using a plastic door panel remover but you can also use an old credit card as well.
Attached Thumbnails Interior rattles, noises and/or creaking sounds?-photo.jpg
Old 11-22-2012, 02:34 PM
  #114
Arrie's Avatar
Thanks,
I'll try and see.
Old 11-23-2012, 01:08 PM
  #115
Arrie's Avatar
Thanks,
I'll try and see.
Ok,
nothing is visibly loose under the plastic piece. I need to have the deck cover that the plastic piece attaches to removed so I can get access there.
Anybody have instructions how to remove the deck cover?
Old 11-24-2012, 04:30 AM
  #116
Grau E350's Avatar
Mercedes product
I'm quite surprised to see that the W212 is still having the continued rattle problems that I had in my W212--dash, command, headliner, rear shelf, etc. I'm disappointed that MB has not addressed these quality problems.
Best of luck.
Old 11-24-2012, 11:08 AM
  #117
Nuru's Avatar
S350 BT 4MATIC
25K miles and no rattles at all. I had a really annoying rattle in my former C300 and for a time I thought it was in the dashboard, but finally tracked it down to the mirror.
Old 11-24-2012, 11:46 AM
  #118
thekurgan's Avatar
E350 BT
I hate to doubt your ears, but you'll be the first to have NO rattles at all in a W212. I think some people are more prone to hearing them, along with a tolerance, but the W212 is loaded with cheap plastic in the dash, wood panels, and the pillars. Wait for a cold morning, don't use the radio or accessories and just listen to the symphony of rattles. I've given up on the small ones, but did address the major rattles.
Old 11-24-2012, 12:44 PM
  #119
W210's Avatar
2000 W210 E55->2003 R230 SL500->2004 W211 E55->2007 997TT+2007 E63->2010 GLK350->2012 E550 4matic
Had mine for a few months, no rattle occasional pana roof noise and that's it. But then, I use the remote start and warm up the car when it's cold in the morning.
Old 11-24-2012, 01:23 PM
  #120
jvc300's Avatar
2011 E350, 2004 911
I have over 22k miles and no rattles or squeaks. I've driven the car up the east coast (twice) and the Midwest and its solid. Yes I drive without the radio sometimes and nothing. I have found noises come from crap in the glove compartment or a soda bottle in the cup holder. None from the car itself. So Nuru is not the first and only...
Old 11-24-2012, 02:55 PM
  #121
El Cid's Avatar
2010 E350 Luxury Sedan, Engine 272 (V6)
Guess I'm lucky, but no rattles in my car. However, the sunroof does creak when opening/closing after car has set in hot sun for a while.
Old 11-26-2012, 04:56 PM
  #122
ngerstman's Avatar
2016 Audi S8 Plus/ 2011 Mercedes e550 4Matic//Gone:1985 500SEL/2000 e320 4Matic/ 2001 e55 Kleeman
My e550 is coming in on 2 years old and around 26,000 miles. I drive on the crappy NY/NJ roads and no rattles yet. I'm very impressed with the fit and finish. Still tight as a drum. Regards. Ned.
Old 11-28-2012, 12:53 AM
  #123
cwarcher's Avatar
Mercedes E350
My 2010 e350 has a noise like a little motor running in the front roof console. It will continue after the car is off for awhile. I first thought it was in the area of the glove box. It is definitely coming from the ceiling. Anyone have a thought?
Old 11-28-2012, 10:05 AM
  #124
thekurgan's Avatar
E350 BT
For those without any rattles whatsoever (still not a believer), how many have the luxury suspension?
Old 11-28-2012, 11:03 AM
  #125
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
45K miles on my 2011 Bluetec and only the slightest"rattle" sounds when going over very rough pavement....99% rattle-free. In my neck of the woods, the Department of Transportation is just as likely to pave over a boulder than remove it. We have some really crappy roads. I find my E to have superior build quality and chassis strength.
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
Quick Reply: Interior rattles, noises and/or creaking sounds?
