Sponsored by: CARiD
TPMS from one wheel to another?
Old Oct 22, 2010 | 03:02 PM
MCF's Avatar
MCF
E350
Anyone know if there would be an issue taking the TPMS sensors from 17" OEM wheels and transferring them to 18" OEM wheels? Can't imagine there would be.
Also, once you get the correct tire pressures in the tires, you can make them the 'correct' settings in the computer by just selecting to make the pressures you have the reference pressures, correct? I ask because pressures in 18" wheels is going to be different than 17" wheels and don't want to have warnings all the time because the sensors from the TPMS sensors are set to a certain reference pressure range that can't be changed. Thanks!
Old Oct 23, 2010 | 02:16 AM
Diesel Benz's Avatar
There are no different sensors anyway for different tyres, these have a fixed lower limit and adapt to the set tyre pressure and have another relative threshold from there (the higher one counts).
Old Feb 17, 2012 | 04:40 PM
BenzV12's Avatar
W212 FL
Hey, I am glad I have found this thread . So, here is my dilemma lol
My ride to be 17" wheels but I would like to change the wheels to 16" which is unusual because mostly owners have an incline of getting bigger wheels . I am attaching an exact image of what I am considering of buying. It looks beautiful
A friend of mine said I should keep OEM wheels because if I go for a replacement I would see a TPMS error message every couple of hundreds miles so I will have to reset the message .
He said he drove W204 C and he picked up that tpms message because of using different size 17 AMG wheels . Funny thing he didn't mention about adjusting the system to the tire pressure you are getting .
So, in a nutsheel, do you think if I trade my 17"s for 16"s and reset the system to 16" tire pressure and inflate the tire 16"s let's say 34 psi all around , system will be OK and not throw fault messages ?
Old Feb 17, 2012 | 06:28 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
No issues, but you'll need a rebuild kit as removing the sensors will require you to replace the o-rings. The kit is universal and costs about$5 per sensor
Old Feb 18, 2012 | 05:54 AM
BenzV12's Avatar
W212 FL
Thanks for your message , I didn't take o-rings into consider
Much appreciated
Old Feb 18, 2012 | 08:16 AM
CorvetteOJ's Avatar
2011 E-350
I guess changing the "O" rings may be a good proactive step but not necessary. I have changed wheels on three of my four vehicles and simply moved the sensors from one wheel to the other. The last one I did was my E350. I have never messed with the "O" rings.
The "E" came with the AMG wheel package. I did not like the dull gray color of the wheels, so I did a core swap with California Chrome Wheel and put the same AMG wheel on the car, but chromed. Once again, all I did was swap the sensors from the dull wheels to the chrome wheels. No problems. I have also changed the wheels twice on my Corvette and simply swapped the sensors, no problems.
Old Feb 18, 2012 | 12:02 PM
BenzV12's Avatar
W212 FL
Thanks Corvette for your reply . I have not decided on the wheels yet . Swapping sensors should work that sounds very plausible too
