Sponsored by: CARiD
tire pressure
Old Nov 2, 2010 | 03:43 PM
FEGELEIN's Avatar
'12 CLS 550 4matic
tire pressure
Age old question, but I was wondering why the fronts call for 36 and the rears 39. Any real reason behind this or the typical 32 all around is fine?
Is it 4 Matic specific, 550 or combo of both, which is what I have?
Old Nov 2, 2010 | 05:45 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
I put 32 front and 33 rear ..
Old Nov 2, 2010 | 06:15 PM
FEGELEIN's Avatar
'12 CLS 550 4matic
What does the sticker on your door say, because you have a 350, which is naturally lighter.
Old Nov 4, 2010 | 11:19 AM
MCF's Avatar
MCF
E350
My 350 says 32 front / 41 rear, but it is a luxury with 17" wheels. I have been curious also as to why they would want more pressure in the rear wheels than the front.
Old Nov 4, 2010 | 12:20 PM
ttoE550's Avatar
2015 GL450
The reason is complicated, involving tradeoffs in comfort, tire wear, suspension characteristics, and whether one wants to make the car to tend to understeer or oversteer (or be neutral).
I personally find it interesting that (according to what I've read) that car manufacturers tend to make cars understeer, with higher rear pressures being a contributor all else equal. This is because most peoples' reaction to a skid is to lift off of the accelerator or brake. When a car has been set to be more neutral, lifting or braking will very quickly put the car in a major spin. This is called trailing throttle oversteer. It is my favorite technique -- hence the TTO in my pseudonym. When I started racing (the cars I drove were very neutral), this was the hardest habit for me to break -- keeping my foot steady and correcting with the steering and, depending on circumstances, actually accelerating to stop a skid.
Sometimes TTO can be used to an advantage. At turn 2 at Lime Rock Park, one often approaches the corner so fast that one cannot steer the car around the turn -- you'd go off the outside of the track. So you momentarily lift off the throttle to put the car in a temporary spin, and then hit the gas when you are pointed the correct direction to stop the spin. THAT was fun!
Old Nov 4, 2010 | 12:55 PM
Tjdehya's Avatar
2023 AMG EQS
Staggered wheels, also Front wheels turn and steer the car while the rear does nothing but follow.
