Sponsored by: CARiD
When you hit a curb at speed
Old Jan 30, 2011 | 03:43 AM
GuyFawkes's Avatar
W163 ML430, W212 E550, R129 SL320
I'm overseas at the moment so no pictures.
My dad was driving the E-Class and apparently he miscalculated and hit the front right rim against the curb when he was making a right turn causing a 2" curb scratch and a couple inche strip of the rubber from the tire wall to come off.
I would imagine this to have been done with some speed and force. Other than the curb rash repair, do you think the car is going to need a new tire for safety? And would you guys recommend an alignment or is that overkill?
Many thanks. Car has 2000kms
Old Jan 30, 2011 | 06:32 AM
WGB's Avatar
WGB
W212 E500, W164 320CDI, W116 450SEL 6.9, W116 450 SEL.
I would repair the wheel, put on a new tyre if there is any damage at all to the sidewall and get a wheel alignment check although most of the newer cars require replacement of offset pins if any re-alignment is required and this is difficult to do outside a dealership.
I hope Dad will be paying - get him while he still feels guilty.
Old Jan 30, 2011 | 10:12 AM
scfishnman's Avatar
2011 E550 Sport (traded), 2012 SLK 350; 2013 GL450 on order for OCT delivery
Definitely replace the tire if there is any sidewall damage. An alignment check may save you the cost of the replacement tire wearing quickly and unevenly..
Old Jan 30, 2011 | 10:53 AM
Tjdehya's Avatar
2023 AMG EQS
I can’t see the damage to the tire but if it looks bad I would STRONGLY recommend that you replace it. High speed Front tire blowouts can be deadly. I almost lost an uncle to one; he missed a light pole by inches and just cracked his skull after hitting the ditch. I also had a coworker 360 on the highway because of one, luckily the road was empty and he didn’t go off the road. I would say you don’t need an alignment unless there is a change in steering/driving feel.
