Sponsored by: CARiD
Renntech Lowering module problem
Old May 29, 2013 | 12:40 PM
hyperion667's Avatar
2012 CLS63
Old Dec 30, 2015 | 09:32 PM
Renntaxi's Avatar
E550 4Matic
Hello guys,
I just installed the V3 module, lowering works without any issues. First i was annoyed about one side is lower than the other. After a short drive i measured again and both sides are pretty in same height.
But i have a question about the module. When the vehicle is going down, does the module adjust the headlight position too? I mean, the adjustment should be changeable automatically?
Any ideas?
Thanks and regards from Europe,
Sibi
Old Jan 1, 2016 | 10:16 AM
shaytun's Avatar
2010 E550 4MATIC
The unevenness drove me crazy at first. Given the constant adjustment of the air suspension the variations are normal based on how the car is parked.
In terms of the headlights I'm almost sure there's no adjustment there, and I don't think any is necessary.
Old Jan 2, 2016 | 09:12 AM
Renntaxi's Avatar
E550 4Matic
A friends CLS500 is lowered by another module called Hilo Tec. This module adjusts the headlight position automatically.
I noticed RENNtech is here on board - hope they can solve the mystery.
For my height an headlight adjustment is necassary. I just don't want to distract other drivers.
Old Nov 22, 2016 | 03:21 PM
flipstah's Avatar
2010 E550 4Matic
BUMP.
How's the Airmatic holding up with the Renntech lowering module so far? Should be enough time to determine reliability.
Old Nov 22, 2016 | 03:35 PM
FromM3toAMG's Avatar
07 E63
Originally Posted by flipstah
BUMP.
No Issues at all.
Old Dec 10, 2016 | 10:51 PM
  #32
RNBRAD's Avatar
W211 E320 & W212 E550
Any premature tire wear issues?
Old Dec 10, 2016 | 10:56 PM
  #33
07 E63
yes, I haven't made any changes to suspension to allow for the proper camber once it's lowered. So I have it set to return to factory height at highway speeds. I can't remember what it was that I need to buy to get proper camber but it can't be done with the factory equipment.
Old Dec 11, 2016 | 12:20 AM
  #34
belarus27's Avatar
2010 e550 p2
Tire wear will occur with any lowering method you pick , unless you get camber kit for front n rear.
I got it lowered on links , amd the inner side of the tire wears out a bit faster.....unfortunately
