Do Current Diesels Have a Block Heater?
2011 E550, 2013 GLK
Do they also heat the fuel?
It's been a long time since I had a Mercedes diesel but we lived in Minnesota and you needed both a block heater and the fuel heated to survive the winters.
But seriously,I don't think that MB offers diesels in the US with block heaters but just might in Canada (I know VW offers them there).As for fuel heating I'm pretty sure MB's diesels have it...I know that my BMW diesel did.And FYI...last January,I took my BMW diesel to central Quebec on an amazingly cold night (-10F at 7PM) and the next morning it started like a charm at -31F.No block heater,no fuel additives,no garage...I must admit that I was amazed! I posted a picture of the dash cluster here shortly after...search my posts if you're curious.
My hunch is that a properly maintained MB diesel could do pretty much the same thing if you're careful to always use locally blended fuel.
2011 E550, 2013 GLK
Something tells me that block heaters and fuel gelling won't be a problem in Phoenix!
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
The E BlueTEC isn't available with a true block heater. They are coming into Canada with an in-hose solution, which you could certainly retrofit into a US-spec car.
2012 S350 Bluetec 4Matic, Diamond White, P2
Block heaters can be added to the US spec Bluetecs. I have been in -12 degrees F and had no problems starting my 2011 Bluetec. Forget just about everything you remember about diesels. Hell, mine produces cabin heat really quickly too.
I think the keys to starting a recently made diesel are 1)a healthy battery that's designed for diesels 2)the correct oil...5W or 0W synthetic 3)locally blended fuel.
Keep in mind that the main reason for the starting isses in cold cliamtes is because batteries lose so much effeciency in extremly cold environs. It's not that the "engine wont start, but, that the batter may not have enough charge to crank it. Battery technology is vastly superior today when compared to batteries of the 70's.
