Sponsored by: CARiD
Wheel spacers?
Old Jun 16, 2017 | 10:26 AM
  #51
ironyforever's Avatar
E350
Why are pictures not displayed; Where do they go?
Originally Posted by PHML
Posting pics for RobbieRob...15mm front....20mm rear.
Thanks bro..
Pete
Old Jul 25, 2018 | 06:59 PM
  #52
2 EURO's Avatar
I recently picked up a used set of Carlsson 1/11 EVO. Specs below
19x8.5 45
19x9.5 50
On one of the wheel/spacer threads, threeMBs mentioned that the best setup for 19s with offset were 19x8.5 33 and 19x9.5 40. So, with that, I'm trying to get these Carlssons to be similar to that setup and in order for me to get there, I assumed I'll need the following spacers.... 12mm(f) and 10mm(R), correct?
Looking at the H&R site seems they don't have 12mm for the front. At least from what the application says, its only for the rear. The smallest front I see are 15mm.
What would you guys recommend?
Thanks,
Mark
Old Jul 26, 2018 | 09:55 AM
  #53
Hsg08's Avatar
MB W212, MB W218, BMW F06, BMW F48
Can you post a picture of your front hub? W212 front hub can be tricky, some front hubs comes longer, regular, and some same hub size as the rear. Also, yes they do have 12mm front spacers for our cars.
As for the front 12mm wheels spacers, you can use regular hub centric, flat type, or the cap ones. Like I said, it all varies what kind of front hub you have.
Old Jul 26, 2018 | 12:34 PM
  #54
2 EURO's Avatar
Thanks for replying. Trying to order ASAP so I can mount these wheels. My hubs in front are normal. Not the extended hub version.
Also, can you also recommend the bolt size to get? I know it’s 14x1.5 but not sure on length. Again thanks for the help on this.
Old Jul 26, 2018 | 03:27 PM
  #55
2 EURO's Avatar
Digging into this further for bolts...
Using the H&R calculation with the stock lug bolt being 28mm (correct me if I'm wrong there)
28mm + 12(spacer) = 40mm new bolt
28mm + 10(spacer) = 38mm new bolt (can I just get the 40mm so that I have same bolts all the way around?)
Mark
Old Feb 13, 2019 | 11:08 AM
  #56
CLS63Matt's Avatar
CLS63AMG W218 • CM7 Accord • '13 Yamaha R1
Reviving an old thread but it seems to be the only thread with information.
I own a CLS63 W218 which is almost an exact twin to the W212.
I want to add 3mm or 5mm spacers for my HRE wheels all around.
1. Do I need extended lugs to accommodate for:
-3mm?
-5mm?
2. Will I run into issues in the rear. It was mentioned above the min spacer we can run in the rear is 10mm because of the lip.
Thank you!
Old Feb 13, 2019 | 11:34 AM
  #57
Hsg08's Avatar
-3mm?
-5mm?
Thank you!
3mm - no extended lug bolts needed.
5mm - yes you need that extra shank length but due to the rear hub lip, 10mm hubcentric wheel spacers required.
Old Feb 13, 2019 | 12:12 PM
  #58
CLS63Matt's Avatar
Thank you!
I also called H&R and they confirmed the same.
Old Mar 3, 2020 | 01:08 PM
  #59
Mmoneyone2012's Avatar
2014 E Class sedan
Where can I find wheel omplete studs to fit a 25mm spacers 14 e class
Old Mar 3, 2020 | 01:59 PM
  #60
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I went with BRABUS wheels (18x8.5) that come with a ET50 offset. They suggested I let them decide on the spacer thicknesses as they know what works best. They provided 10mm spacers for the front and 16mm spacers for the rear. So I ended up with offsets of ET40 in front and ET34 in rear.
I'm satisfied with the flush factor - in front that's as far as I would want them to be as far as being flush with the fender but in the rear, I think there was room for another 5mm or so.
I'm not going to push it though because I don't want to end up with problems such as ruining wheel bearings.
Search for Alloy Wheels Direct. I believe they can source custom length bolts.
Old Mar 3, 2020 | 02:41 PM
  #61
GuestFromTampa's Avatar
W212 E250 BT 4M
I would only buy lug bolts from https://otisincla.com/
their lugs are made by cold-forging , they are not cheap but well worth it.
Old Apr 19, 2020 | 04:19 PM
  #62
jrv777's Avatar
w212 e350 2014
Spacer size for this AMG factory wheel for paper thin flush
What spacer size do i need for front and rear for papr thin super flush
Old May 2, 2020 | 04:04 PM
  #63
manishjain24's Avatar
W212 E400 4Matic < W211 E350 4Matic
This is the setup I plan to use on my car, i believe this will be as close to paper-thin as you can get.
Front: https://www.ecstuning.com/b-h-and-r-...-pair/3055665/
Rear: https://www.ecstuning.com/b-h-and-r-...pair/40556654/
Bolts for rear: https://www.ecstuning.com/b-h-and-r-...ch/1454302~hr/
I, however, believe you have a bigger issue, I see there is a bubble in your tire. While it seems small, it can be quite hazardous and result in $$$$, my 2 cents.
