Command engineering menu
As it has been discussed in other threads about how to activate internet in command 4.5. while I was enabling that in my car I noticed there are two other options that looked interesting and were disabled:
Dualview: Is that same as option available in S class where driver sees another view and front passenger gets to see different view on the same screen?
MB Svc: Anybody knows what they are referring to?
I got internet working but after enabling the two above options I do not see any thing changed...anybody tried enabling the above two options I mentioned and got it working...?
Thanks in advance!
If you still choose to enable other options, in order for them to work, you need to go back to the main menu, scroll down to RESET (I think it's number 9) and then RESET the system. This will NOT delete any personal info like addresses, settings, or Bluetooth, but will enable or disable anything you changed in HU Parameters.
