HID's installed
Old 12-15-2011, 09:02 AM
  #51
alloutmk23's Avatar
2011 E350 4-Matic Sport
nice find
Old 12-15-2011, 09:22 AM
  #52
alloutmk23's Avatar
This is a very subjective topic. Even if they were illegal, it's only because of glare (which i agree, no drivers should be blinded).
Some people believe that all HIDs cause glare and some obviously don't. Bigigg has said multiple times that he wouldn't install them if they blinded other drivers, so he obviously tested them or adjusted them like I have with mine. Illegal or not, his HIDs do not blind people..end of story.
Its sort of like limo tints. They are illegal too, but that dosent stop members on this forum/tint shops from installing them. I myself have tints, however when I see a person with limo tints, I don't badger or persuade them into taking them off.
Old 12-15-2011, 10:02 AM
  #53
captj3's Avatar
2019 CLS450 4 Matic 2011 E550
Bigigg which LED bulbs did you use? Also what did you use for the high beams as I won't put hids in those.I just installed HID's in my car and diference is night and day. Mine are adjusted properly so they don't blind on coming traffic. I read CEBs links. They mostly are talking about the scatter affect you get when hids are put into non projector housings. By the way my hids are 35 watt not the 55 watt option.
Old 12-15-2011, 10:21 AM
  #54
bigigg's Avatar
14' CLS550
194 wedge bulb by aznoptics 5000k color, i love them.. high beams are stock, no reason for me to change them out. Im also running 35 watt kit.. 55 watt burns hot and chance of melting, no need for it, 35 is plenty.. I'm done talking about CEB, lol.. in my eyes hes useless on this forum.. look at his threads/post.. perfect proof
Old 12-15-2011, 10:24 AM
  #55
captj3's Avatar
Thanks for the reply. Yes I know what you mean.
Old 12-15-2011, 10:50 AM
  #56
CEB
CEB's Avatar
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
I think it is time that we bury the hatchet and put this one to rest. I do want to clarify the legality of these products.
They are clearly illegal. See 19609
An explanation is on page 49600 of the Federal Register / Vol. 66, No. 189
"Another disturbing trend in this lookalike phenomenon is the substitution of OEM filament headlamp bulbs with aftermarket HID conversion bulbs. The desire is to achieve the look and achieve the more robust performance of HIDs. While not designed to be interchangeable, some aftermarket companies are substantially altering the HID bulb bases or providing adapters so that the HID bulbs can be inserted in headlamps designed for filament bulbs.
The consequence of making these substitutions is to adversely affect safety. Filament headlamps are optically designed for the volume of light and filament placement and other critical dimensions and performance that OEM filament bulbs have. The HID conversions result in two to three times the volume of light and potentially imprecise arc placement. Such conversions often result in beam patterns that behave nothing like the
original filament beam pattern, cannot be reliably aimed, and have many times the permitted glare intensity. In informal conversations with persons
who have tested such conversions, the light intensity on one at a point aimed toward oncoming drivers was 22 times the allowable intensity limit. Another lamp was more than 7 times too intense.
With poor HID bulb and arc placement, the glare intensity could be significantly worse. Thus, the use of these conversions could be yet another source of the glare problems about which many drivers have complained."
Even SEMA has talked about the illegal HID conversion kits. From the SEMA website comes this:
Is it legal to sell HID replacement kits?
NHTSA has concluded that it is impossible to produce HID conversion kits (converting a halogen system to HID) that would be compliant with FMVSS No. 108.
Just because a headlighting unit has a projector beam (made for a halogen bulb) does not mean that it is suitable for a replacement HID capsule. The beam patterns for the two lighting sources are completely different requiring a different reflector or projector design. The pictures supplied by the OP clearly show excessive glare. While he may not think they produce glare, he certainly hasn't had them checked. Based on the install, those lamps must produce excessive glare.
While states cannot change or disregard Federal requirements (i.e. they cannot say " HID conversion kits are legal",) they can decide to not enforce that particular requirement during periodic inspection or traffic stops. Many states don't worry about side marker lighting during inspections and the ones that do check (PA comes to mind) then stand out.
I'll let you have the final word. I'm sure we'll be discussing this in another thread.
Old 12-15-2011, 10:56 AM
  #57
CEB
CEB's Avatar
Originally Posted by bigigg
This is part of an article where a gentleman states he called his local dmv and state trooper barrack..
"I first called my local state police station and asked to talk to the officer who handles the traffic infractions. I asked him if HID's were illegal in halogen light vehicles. His initial reply was they do pull over drivers with them. I asked why and he stated cause they were blinding. Halogen based vehicles have higher lights cause halogen isn't as bright. Xenon is significantly brighter and in stock housings can be blinding cause they go straight into oncoming traffics eyes. Just find a way to angle it down some. I asked for an actual law stating they were illegal and he put me on hold. He came back to say they is absolutly no law in NY or federally saying they are illegal. You can get pulled over if they are preceived as blinding to the police officer but that's the extent. He went on to say he checked the supreme court rulings and there has never been a case brought up where someone or some group have contested it as a law.Basically in NY and on the federal level it is 100% legal to drive with them in halogen housings. Granted state laws can make aomething illegal that the federal level deems legal(though not vise versa) so check your state athorities. Next i tackled the notion of failing an inspection. I called my mechanic and he told me he has never failed nor knew anyone who failed someone who had aftermarket HID's. To verify i called the DMV to confirm i would pass an inspection. Again both state wide and federally there is no law against it. The only thing that is looked at when getting an inspection is if a vehicle has high beams and low beams. Im posting this for the people who are currently looking to see if its legal or not and may be confused by the people who really don't know what they are talking about or stating false statements they may have read or heard from someone else"
Just because some random guy posted a thread about allegegedly getting information from a DMV doesn't make it so. In addition, if you're going to quote something, you might want to add the source. I have posted several documents clearly showing that putting a HID bulb in a housing designed for halogen is illegal. There is no question about that aspect - which begs questions about the rest of this "article."
I'm out of this thread. The forum now understands (if they want to) why these HID conversions are a bad idea. My offer still stands.
Old 12-15-2011, 11:27 AM
  #58
bigigg's Avatar
14' CLS550
Yea good luck trying your hardest to convince other forum members who have already installed hid's that its a bad idea.
Old 12-15-2011, 12:05 PM
  #59
Invain15's Avatar
4matic C300
Bigigg,
I agree with you, it is your car and you can do as you please and the HID looks great. I'm sure you had to notice some type of difference. I hear people all the time saying they blind other people. For the record, all hid's are bright and compared to halogen can blind anyone. No matter where they're aimed. Just depends on the driver. I know the cutoff looks like crap when you're next to a wall but who gives a crap about that. How often am I going to be in a parking lot, staring at a wall wondering if my cutoff is correct. NEVER. Good to see you got this installed and it looks great.
Old 12-15-2011, 08:03 PM
  #60
Gsc
Gsc's Avatar
2014 S550, 2014 Porsche Turbo S, 2013 Bentley GT Speed W12
CEB- The official HID Po-PO!
Old 12-15-2011, 08:13 PM
  #61
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
To Invain15, I completely understand what you mean. My S550 stock bixenons are much more blinding than anything I've done to my E, so to everyone: don't listen to CEB . He obviously doesn't know that bixenons are much more blinding than HID kits.
Old 12-19-2011, 02:42 AM
  #62
BM2BZ's Avatar
w212 E550
i have hid/xenon lights (factory option) in my bmw and now i need them on my non-p2 w212 e550. but i guess it could be a wrong time to ask more questions in this heated thread.
Old 12-19-2011, 07:31 AM
  #63
captj3's Avatar
No it's not the wrong time. Just ask away.
Old 12-19-2011, 01:40 PM
  #64
Gsc
Gsc's Avatar
I would not let 1 jerk sway your opinion.
Ask away..
Old 12-19-2011, 02:00 PM
  #65
CEB
CEB's Avatar
Ask away..
Feel free to ask. It is very humorous that the people degrading their vision are calling the individual that tells them what the law is and why it degrades their vision a jerk. I guess they would rather be surrounded by Honda Civic drivers that ohh and ahh over every new purple light bulb they've installed - no matter how tacky it is.
Now that you know what the law is and what the downsides are, you can make your own decisions.
Old 12-19-2011, 03:09 PM
  #66
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
Seeing how these aftermarket lighting threads go, I am not even gonna ask for anyone's opinion on my Disco-era halogen strobe lights I have mounted in my E's stock housings. Makes everone look "stop-action" at intersections. Love them at night time. Nothing like being flipped off under a strobe effect. Now if I could just figure out where to mount my Black Light turn signals.....
Old 12-19-2011, 03:29 PM
  #67
BM2BZ's Avatar
w212 E550
i'm no peacemaker by all means but can we all just move on and make this forum a happy place for people who love their rides? i'm just a newbie here but have been a looooong time member at the other bmw forum. i have finally registered yesterday simply because i like this forum more than the others. i sure hope i did the right thing.
Old 12-19-2011, 06:38 PM
  #68
captj3's Avatar
I guess reading and comprehending is your downside. Where do you see that I called you a jerk? I just answered his question.
Old 12-19-2011, 07:29 PM
  #69
CEB
CEB's Avatar
You didn't. Chill. I agreed with you that he should ask his question.
Old 12-19-2011, 08:46 PM
  #70
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
I think HID conversion kits are ok if the cutoff lines are straight and distinct, with little or no glare above the cutoff line.
On a side note....not sure if this is still the case, but years ago, I remember seeing that HID conversion kits usually have a disclaimer of some sort....like "For Off-Road Use Only"....or...."Not For Street Use". Anyone else remember seeing this disclaimer?
Old 12-19-2011, 09:04 PM
  #71
CEB
CEB's Avatar
Originally Posted by PHML
...On a side note....not sure if this is still the case, but years ago, I remember seeing that HID conversion kits usually have a disclaimer of some sort....like "For Off-Road Use Only"....or...."Not For Street Use". Anyone else remember seeing this disclaimer?
Correct. Most aftermarket lighting companies use a "for off-road use only" disclaimer believing that will keep them out of trouble. Unfortunately, there are many NHTSA legal interpretations that plainly state that if a product can be mounted on a street legal car, then that product must comply with all of the regs. In addition, NHTSA has consistently held that "off-road use only" is not a recognized term under the law.
There is no question that aftermarket HID kits are illegal. In addition, all of the technical experts throughout the world have recognized that it is impossible to design a HID kit that works properly. This isn't conjecture or fanboi'ism but fact.
Old 12-20-2011, 05:24 AM
  #72
bigigg's Avatar
14' CLS550
I guess were just a bunch of rebels breaking the law.. wow i feel soo bad @ss! This thread should get deleted, the more i see it the more i get annoyed with CEB.
Old 12-20-2011, 06:27 AM
  #73
CEB
CEB's Avatar
Why get annoyed with me? Because I pointed out the law and the downsides of your mod that you had not considered before? Because you are now stuck with a mod that degrades your visibility and need to try to justify it to yourself and to the forum?
I do not care what you do. I just want to make sure that forum members have the facts before they make a mod.
What annoys me is when posters come back with made up personal opinion that they try to pass off as fact. I've said it before, I'll say it again - I've put my money where my mouth is and have offered up a gift card for you to show this forum any study, report or similar document from a reputable organization or Government entity that demonstrates a benefit of putting HID bulbs into housings designed for halogen bulbs.
I can make that offer because such a study does not exist.
Feel free to do what you like - just don't try to convince others that the mod is safe, legal or provides a benefit.
Flame on, because that is the only way you can save face with your peers here on the board using the standard internet bully principles - if you don't have facts to back you up then try to ridicule and intimidate.
Old 12-20-2011, 09:02 AM
  #74
bigigg's Avatar
14' CLS550
I can care less, and def dont need your gift card offer BS!.. You keep talking this legality crap that no one cares about, thats my point. Your trying soo hard to get the "facts" across but reality is no one cares! Theres hundreds of people getting pulled over for there after market hids as we speak.. NOT! Get over yourself, your convined im trying to "save face" you couldnt be anymore wrong. I have nothing to prove and no one to impress. And you truly need to get a life. Also your not the one sitting in my drivers seat soo what do you know how my visibility is? I can care less about your links that some other jack @ss wrote up..GET A LIFE DUDE! Better yet go buy a w212 before you even respond to another post..
Old 12-20-2011, 09:07 AM
  #75
CEB
CEB's Avatar
Thank you for validating my last paragraph.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
Quick Reply: HID's installed
