Sprint Booster!
We encourage you to reach out to customers who have posted reviews on this forum over the past 4 years and follow up to see what their feedback is. We are certain they will be mostly or all positive.
Cheers,
Sprint Booster USA
A comment we often hear from our customers is that they fall back in love with the vehicle they have been driving for years. Many are pleasantly surprised within the first few seconds. It starts with that first press of the pedal.
We admit, our product won't be for everyone. But many who try it love it!
Am I the only one who notices the marketing-like lingo of the OP? LOL stuff like that only flies on this forum. It is very clear that the OP is being paid to pump up sprint products. This type of stuff is not new to forums. Advertisers/Mfr's do it all the time on forums and it's very very obvious and it HURTS their rep.
You guys can say all you want about the sprint booster. The reality is you are throwing your money away!
How about we see some REAL results. Not dyno runs, because those can be fixed. Do it the right way: go to the track an put down some good 1/4 mile times. PROVE IT. Back your product sprint!
Just my two cents. The MB world looks like the Audi world did 5 years ago. Fancy advertisers with fancy charts and fancy members pimping their stuff.
I can't believe the accusations that go on this forum. Its amazing how immature people are here. You'd think a MB forum would have educated professionals. Instead I se a lot of conceded immature brats.
I installed the SB in my 2010 E350 because I wanted a tighter feel to my acceleration. The SB accomplishes this without adding any HP or doing anything other than allowing me to push lighter on the gas to get the desired acceleration result. I've had it installed and operating for about 30K miles to date with zero issues, no MB tech comments, no questions at service times.
If anyone is in Nor-Cal and wants to feel the difference, PM me. You simply turn off the SB and tap the gas. Then turn on the SB (green mode) and tap the gas. If you want a further difference turn on the SB (red mode) and tap the gas.
Most of my friends and family that have tried this on my car can feel the difference, and they (as I did) like the difference. Yes, I could mash the gas harder for a similar feel with zero cost, but I also could have bought an E550 or E63 if I wanted that feel.
Geez ... can we be civilized now?
What I've been saying is that I personally don't think that the attributes I hear of it don't suit how I want my Luxury Car E-Class to feel. As well, I've always enjoyed the "mature" pedal-travel and feel of an M-B, which would obviously diminish if you're going from 20%-80% at the same push. If I drove, or wanted to drive my car more aggressively, or if I had a car I intended to use as a sportier car with more power, I'd probably get one to just make it feel as fast and responsive as possible.
As I understand it, the throttle response is nonlinear, according to a white paper someone posted. So for the early part of the throttle range the throttle is mostly unresponsive, and then at some threshold it decides you really meant to press the throttle and suddenly makes the mapping aggressive. It is this sudden switch that screws up a good drift or, for that matter, keeping the car balanced when taking a corner a bit faster than usual. Simply pushing the pedal harder is not the answer as good fast driving is 100% about balance (and the smooth transfer thereof).
I wouldn't care if the pedal had a lot of travel so KA could have his smooth takeoffs as long as, say sport mode made the throttle linear. Perhaps what SB does is keep the throttle beyond the threshold so that there is no change in mappings. Yes, it might be twitchy, but if so one would get linearity. Dunno
The manufacturers play on this of course with lots f very carefully worded gobbledegook to confuse the casual reader. An example comes from the Sprint Booster website
"It is a device that improves acceleration by continuously measuring and converting the digital signal provided by the ETC’s potentiometer, and providing the ECM with a new and altered signal."
Truth be told, the Sprint Booster does not technically improve acceleration. It merely allows you to get the same acceleration that the car already has - you just get there by pushing on the gas pedal less. In the FAQ, they say that the SB by itself does not use more gas. Technically a correct - but misleading - statement. More acceleration at a lower gas pedal setting by definition means more gas getting sucked into the engine.
So, does this make it a bad mod? Not necessarily as long as you understand what you are paying for and understand the warranty implications.
Are there warranty implications? From the SB website "It is a device that improves acceleration by continuously measuring and converting the digital signal provided by the ETC’s potentiometer, and providing the ECM with a new and altered signal."
Providing an "altered signal" is considered by most manufacturers as modifying the car's computer.
Finally, this device alters or bypasses safety devices built into the car. I suspect that the use of the SB would be frowned upon by anyone remotely connected to the "unintended acceleration" issues.
Accordingly, only once you've properly considered all the upsides and downsides can you make an informed decision about this or any mod. From reading this thread it seems like some readers attribute magical qualities to this mod - when in fact all it does is step on the gas harder.
I have long legs anyway, so pushing the pedal harder to get the same results isn't such a "stretch".
* TUV approval as an automotive product. http://www.tuev-sued.de/home_en
* Multiple SEMA awards by our industry peers including best new product in 2010.
Our product speaks for itself and usually exceeds the expectations of the user. Again, Sprint Booster may not be for everyone. But those who "try it" tend to like it a lot and become repeat customers.
I do not have one installed in my 2010 E Coupe because it's my wifes car.
This paper that everyone refers too was written in 2007 and the vehicle used in the test was a 1999 MY Benz. A little out of date. Oh, and by the way after checking out the author (5 years ago. He had a company marketing a similar product only better of course).
I apologize if you think I was one of those you think as being stupid or lying but you have no idea what my right foot can do until you see it...
Now for our cars we have to modulate the pedal push in order to obtain the proper amount of acceleration. Generally 1/2 down to the pedal will obtain the proper on ramp merging and lane switching acceleration. Now does this product make the car similar to a toyota acceleration or does do it via mercedes kick down into the optimal gear for quicker acceleration.
TIA for any further clarification.
