WHEN DO YOU REPLACE TIRES?
Do you replace your (in my case, Michelin Primacy MXM4 ) tires when wear reaches the wear indicators, 2/32? Or how much before? 4/32? Even before?
The old school of thought was 2/32nds but that effectively meant that the tires had lost all ability to evacuate water. The new rule of thumb is that you replace the tires at 4/32nds.
By the time the wear bars are showing, you've lost all ability to drive in rain and even a water puddle can cause issues.
Don't believe me? Read it on Tirerack. Yes, they are in the business to sell tires but they are also the undisputed experts in consumer tires. I could show you NHTSA test results but they aren't in anything remotely resembling the English language.
For ease of measurement, let's assume 8/32nds and treadwear of 40k miles. Accordingly, each 32nds will give you about 5k miles - however - as tires wear, they become more susceptible to road hazards so you'll want to factor that in as well.
Me? I'd probably swap the tires out before the trip if they were at 4/32nds, but any non-paranoid sane person would probably keep them if they had even tire wear and we're at 4/32nds.
Would i take a 3000mile trip on tires that are borderline? Not a chance.
The tires you have on your vehicle can completely make or break your satisfaction level, in my opinion.
I've never received bad advice from a TireRack rep. In fact, i think they are the most knowledgeable and accessible people in North America for wheel & tire information. Self-serving is not an accurate description of TireRack. If you know of a better & more complete source, please share?
I do not work for TR nor do I have any affiliation with them. You don't like TR? Fine, then how about the German equivalent of AAA? ADAC states"
Profiltiefe
Bereits bei einer Profiltiefe von 4 mm nimmt die Haftung des Reifens, insbesondere der Breitreifen, bei Nässe deutlich ab. Die Reifen können den Wasserfilm nicht mehr verdrängen. Sie verlieren den Kontakt zur Straße, das Fahrzeug lässt sich nicht mehr lenken und bremsen. Deshalb Reifen nicht bis auf die gesetzliche Mindestprofiltiefe von 1,6 mm abfahren. Je nach Breite der Sommerreifen spätestens bei 2 bis 2,5 mm, Winterreifen bereits bei 4 mm Restprofiltiefe erneuern. "
For those of not able to read German, let me (loosely) translate.
Tires, primarily wider tires, already begin to lose grip in wet conditions at 4mm (about 5/32ns.) The tires are no longer able to evacuate water. They lose contact to the street and the car can no longer be steered or braked. Accordingly, you should never drive a tire down to the legal limit of 1.6mm (between 2 and 3/32nds.) At the latest, change the tires at 2 to 2.5mm tread depth (3-4/32nds,) and wintertires no later than 5/32nds.
OEAMTC,the Austrian Automobile club, recommends the 4x4x4 method of changing tires - all 4 at one time, no less that 4 mm tread depth and no older than 4 years. 4mm is roughly 5/32nds.
If you'd like it in English, the here it is from Tirerack and AAA who actually recommend 4 or 5/32nds but no later than 3/32nds.
But back to Tirerack and being the "undisputed" authority on tires. Every US car magazine links to TR tire testing and most magazines use the TR testing facilities to test tires, but that is really unimportant since neither ADAC, OEAMTC or AAA sell tires and they all say the same thing.
Whoops, I forgot Consumer Reports.
Are you one of the guys on page 31?
At these tread depths it is a role of the dice as to how much water you will encounter and the ability of the tire to deal with it at the speeds you typically drive at.
... time for new tires.
