Really blind blind spot area
When you get a new car chances are that the mirror does not tilt with reverse gear on even if the selector switch is set to passenger side. This is because the mirror has not been set to the tilt position yet as from the factory it probably is not.
I had this with my 2011 E350 as I got it as a new car. I had to first set the mirror position for the tilt. This was simply done by having the reverse gear on and adjusting the passenger side mirror to position I wanted and leave the selector switch on passenger side.
To disable the tilt just press driver side selection and it will not tilt until you select passenger side again.
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
My 2005 E500 did the same thing.
