Little annoying rattles, etc and fixes
So yesterday im at the gas station open the fuel door fill the tank go to close it and it wont engange back into its original closed position. After tinkering with it for 20 minutes and thinking damn ive got to take the car in for this bs, i found then problem. Talk about silly. The plastic cord that holds the gas cap was swiveled too low at the base. I turned it counterclockwise and bam the door engages and locks into position.
I had an annoying rattle in my roof above the rear passenger seat. Took it in and it turns out then A pillar was loose. They fixed it and i dont have any rattle in the roof anymore.
Ive hit the bottom of my front lip on curbs parking a few times, and ended up with the paint completely scratched off in large sections. My car is iridium and i dont think MB makes a spray paint or any other manufacuter. The closest ive found (and its a good match) is Dupli Color perfect match for chrysler the code is BCC0338 radiant silver Metallic. I got it at autozone. Im sure you can find it elsewhere
I didn't want to waste time with the dealer again and took the central console apart. Found two screws holding COMAND unit incredibly lose (pretty much not screwed in al all). Tight those two screws up and voila! the squeak was gone.
Some much for the dealer.....
The bolt behind the srs cover needs loctite, my driver side practically fell out when I removed the srs cover. In fact I felted the entire a pillar behind the whole cover, it needs it.
