no sound from e350 comand unit
Got lots of good info here, so I appreciate any and all feedback.
I picked up a 2010 CPO E350 4Matic just a few weeks ago.
Did not have the new 2012 v.7 maps loaded on delivery, and did not have Bluetooth streaming, so after a week of driving it, initially, i contacted the dealer, and had them update the maps and comand software free of charge.
Since then, I have noticed some intermittent issue. Occasionally, when entering the car, I power on the comand (unit) before driving, and I get no sound. Everything absolutely works, nav maps come up, connects to my phone, song names show up, but there is ZERO sound from the speakers.
It gets very frustrating, especially when in a rush to go to work in the morning.
I have to restart the unit (turn off, turn on) maybe 15 - 20 times before the sound can come back. If I go to the "system" menu, then reset the entire unit, and wipe data, the sound comes back instantly.
Can anyone offer an possible solutions, or what this can be, or if they experienced this before.
It took me 2 days and 4 employees just to explain to my dealership that my car did not have the latest comand software, just for me to get the bluetooth streaming enabled, so i feel that going to the dealership will be complicated, since they are not tech savvy, which also does not make sense to me.
Any recommendations/suggestions are appreciated. I am under warranty, only have 35k miles on it, and then have the CPO warranty, so that is not the problem. It might be difficult to exactly replicate the issue, as I cannot run to the dealer the second the issue happens, I work during the week, cannot go to the dealer at my leisure. and need everything working!
Thanks.
On mine, the sound failed and after about 40 minutes of driving it restored the sound just before I could demo the issue to the dealer.
Good luck.
Wayne
Anyway, when it happens I've tried to drive straight to the dealer only to find that on the way there it starts to work... Shooting video of it seems like a good idea because since no fault codes show up, it is impossible to see anything wrong.
- always happens from a cold start and never happens once the system is running.
- I know when it isn't working because the warning beeps when you turn the ignition on are not audible.
- trying to switch to a different audio source does nothing. In fact it appears that the COMAND unit no longer sees some of the sources because the satellite radio no longer appears on the list of sources nor does the traffic soft button appear on the nav screen.
Might just be coinkeedink...
I've got a video of it not working but haven't been into the dealer yet.
My dealer said that MBUSA wouldn't let them replace the COMAND unit on a whim. However, with enough supporting evidence (like the video you had in the first place), I'm surprised they didn't take that step. I'm also not surprised that they can't find anything wrong. If no error is thrown, they're not going to find anything wrong.
I'm beginning to wonder if the problem is heat related since I seem to be getting it more and more frequently now that we finally have warm temperatures in the Pacific Northwest.
I also found three fault codes in the Engineering Mode log: two are "DTCc020 B-CAN driver error" and one is "DTCc146 Lost com. with CGW"
I've not been able to find out too much about them, but I believe that the B-CAN (CAN-B bus) has the audio gateway and the central gateway (CGW) connected to it. The codes have temperatures logged with them which are 34, 42 and 55 degrees (Celcius) respectively. The first temperature is only about 90F but the last two are much higher.
