Sponsored by: CARiD
wheels for 2011 e550 4matic?
Old May 24, 2012 | 10:53 PM
onemangang's Avatar
2011 e550
Just bought a brand new e550 4matic, and looking to put after market rims on it. I went to my wheel dealer and he said I can run 20x10 on the rear, and 20x8.5 on the front. Will this fitment work?
Old May 24, 2012 | 11:26 PM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
It depends on what offsets they offer.
Old May 24, 2012 | 11:30 PM
onemangang's Avatar
2011 e550
What offset will it require, and what are the proper tire sizes? I don't want to get suckered into making an uninformed purchase. Thanks
Old May 24, 2012 | 11:48 PM
oggie's Avatar
Factory 18" offset is +48. Tire Rack sells both +35 and +45 offsets for their wheels. Fronts would be 245 and the back can fit 275 if you want to run stagger set.
Old May 25, 2012 | 01:52 AM
onemangang's Avatar
2011 e550
I loved the staggered fit, and the aggressive look it gives the car. The guy I talked to told me I could get 285's on the rear on a 20x10 wheel.
Old May 25, 2012 | 08:34 AM
threeMBs's Avatar
Only MBs - the best or nothing
In order to run staggered 20" fitment on W212 E-class 4matic, these are your only choices:
1. 235/35-20 front and 275/30-20 rear - both front & rear 26.5" diameter
2. 245/30-20 front and 285/25-20 (only with 10" wide wheels) rear - front same as stock 25.8" diameter, while rear is a bit less at 25.6" (not ideal for 4matic, but still OK) .
The problem I see with choice number 2 above is that sidewall (if one can call it a sidewall) is almost non-existant IMHO.
Naturally I much prefer choice number 1 above regardless of the drive configuration.
