Even more confused about new line up of V8...
Ok so all new V8 engines are 4.6-4.7L Twin Turbo
E, CLS 550 402 HP
S, SL 429HP
2013 GL 550 same as S class
2013 GL 450 362 HP
2013 GL450 "...continues to use a 4.7-liter, DOHC V-8, but it's far different than before. This new engine is part of Mercedes' new family of direct-injection, twin-turbocharged V-8s, and whips up 362 hp from 5000-6000 rpm, and 406 lb-ft of torque from 1500 to 4000 rpm". (from motor trend)
Are these different engines or all the same just tuned differently?
E, CLS 550 402 HP
S, SL 429HP
2013 GL 450 362 HP
2012 S350 Bluetec 4Matic, Diamond White, P2
Who cares? You got what you got. I would think it is just different tunes, although, the higher output motors could possibly have more robust parts. Next time you are at your dealer, stop by the parts department and see if there is a different part number for things like turbos, pistions, valves, etc.
18'Porsche GT3, 16' Ram 3500 mega diesel,30' Model A Ratrod, 17' E43
All the same motor, just different programs and mapping through the computer. The 429hp tune is in the S, SL like you said but also in the CL. These cars are a bit heavier so require some extra hp to perform like the 402hp tune in the E and Cls. These new motors are real easy to make more HP(change the tune) compared to the older NA engines. Aftermarket companies will be making a fortune on tuners.
