12v outlet no longer in glove compartment?
Subscribe
May 25, 2017 | 03:21 PM
Quote: Not sure I did the test correctly, but the lighter socket doesn't draw power when the car is off / lock the doors and walk away.
If the Mercedes German engineering is anything like my BMW, the 115v adapter will draw power even when the vehicle is off...I came back to the adapter hissing and sparking and HOT.
Reply 0
May 25, 2017 | 03:56 PM
Quote: If the Mercedes German engineering is anything like my BMW, the 115v adapter will draw power even when the vehicle is off...I came back to the adapter hissing and sparking and HOT.
I agree, but the cigarette lighter package is not 115V I believe. It is just a 12V, right below the radio.
Based on what I read, the rear passenger one, behind the center console(under rear a/c) is 115V(if we have the package) and I'm not even using it.
I can experiment with the front cigarette lighter one today and post the results.
Reply 0
May 25, 2017 | 04:00 PM
Quote: I agree, but the cigarette lighter package is not 115V I believe. It is just a 12V, right below the radio.
No, that's not what I am saying...
I was referring to the 115v adapter you posted the link to above.
If you plug that into the 12v cigarette lighter, then it will draw power and hiss and get really got and possibly overload...does that make sense now?
Reply 0
May 25, 2017 | 05:26 PM
Oh, I thought it won't overload, as it was designed for the cars to draw from 12V socket, to charge bigger appliances, as per comment section, which is popular 'breast feeding pump', Laptop or iPad, to blow air mattress(camping time) etc.
Reply 0
May 25, 2017 | 07:13 PM
I do not think it will overload... ive used one of those a
"Converters" back in the day on my bimmer and it worked fine to charge my laptop. Havent tested it on my benz , but i do think , that u should be fine if you use a converter.
Reply 1
May 25, 2017 | 07:15 PM
I just actually checked that Amazon link that you have posted earlier... and i did have something similar before , so just buy it and be happy. A pretty useful thing on long trips... esp. If you have kids.
Reply 1
May 25, 2017 | 07:33 PM
  #32
I found th4 12V in the trunk
Also, just saw it on the cap of the middle outlet(back seat passenger) and it is marked as 12V.
Reply 0
Mar 31, 2021 | 12:50 PM
  #33
Trunk has 12v plug
Quote: I was searching for a location to plug in a 12v accessoryi and found posts mentioning people using the 12v plug inside glove compartment. I looked and looked but couldn't find one in our car, except what looks like a covered up hole on the right side. Peeking through the side opening confirms nothing is wired to the back.
I couldn't tap into other 12v sources since this accessory has a built in step down voltage regulator in the plug, and thus need to be plugged into the cigarette lighter type of port.
Does this plug in glove compartment require some option we didn't get, or was it a victim of cost savings in the 2012's?
trunk has one
Reply 0
Explore
Mar 31, 2021 | 04:24 PM
  #34
way to go resurrecting a 5 year dead thread for your first post...lol
especially seeing the last post has a picture of and statement about the socket in the trunk.
Oh yeah, Welcome to MBWorld!
Reply 0
Mar 31, 2021 | 09:37 PM
  #35
my 2016 wagon has one at the ashtray, one on the back of the center console, and another in the trunk area too.
if I was wiring something like a dash cam that was going to be semi-permanent, I would likely pull out the glovebox, find some useable 12V behind it and wire in a 'cigar' outlet with its own fuse (or maybe parallel it with the ash tray cigar outlet wiring), then tuck all this in behind the glovebox.
something like this,
Amazon Amazon
since the plug is inaccessible, I would wrap it in tape, or maybe a couple tiewraps so it doesn't vibrate loose with age.
or, drill a hole in the glovebox (after verifying clearance behind it) and mount something like this so your widget is plugged inside the glovebox.
Amazon Amazon
(same deal, wire it in parallel to the cigar outlet in the center console, or find 12V aux power somewhere handy)
Reply 0
Subscribe
Currently Active Users (1)
