disadvantages in 4 matic
BTW Audis, except Lambo based R8, all use non-staggered OEM setups.
Yes, and now we are splitting hairs.
I am perfectly aware that tire setup that gives the same tire diameters in front and back will work but the one MB has selected for these cars cannot be used.
Also, go put a set of those that you mention under the 4Matic E and then when the 4Matic center differential fails go ask MB to cover it under warranty. Good luck!
Really? Just put stocks back on prior to taking car to dealer. How hard is that? I did not think I had to mention it.
Regards,
Don
On my formal E500, an MB dealer charged me over $3K to replace transmission, radiator and more after warranty expired. That "repair" was due to faulty supllied radiators installed in many early W211, W203 and some others (W211 board is filled with those effected). MBUSA knew about the problem. They also knew that those supllied radiators fail (by far) only after warranty expired. No recall. No extended warranty on effected parts (similarly what they've done with SBC brakes). So please, do not appeal to my conscience.
o When you wish you had staggered wheels, you put them on even though you're not supposed to.
o When you put staggered wheels on that you're not supposed to, you ruin your transmission.
o When you ruin your transmission due to using staggered wheels that you're not supposed to be using, you replace them with the originals and take car to the dealer to fix under warrantee.
o When you take car to dealer to fix under warrantee even though you caused the damage with staggered wheels, you commit fraud.
o When you commit fraud, you feel guilty and have difficulty sleeping at night.
o Don't commit fraud, feel guilty and have difficulty at night.
o Get a RWD to begin with!
