What fuel do you use??
Old 08-01-2012, 07:08 AM
  #51
hyperion667's Avatar
Received 3,399 Likes on 2,844 Posts
2012 CLS63
also like to use a little bacon grease........it doesn't mix with the gas, and also produces a really pleasent bacony smell
you guys should try it
Old 08-01-2012, 07:38 AM
  #52
CEB
CEB's Avatar
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Originally Posted by Arrie
Octane rating affects the car by what the engine is made to run with. If it is a high compression engine, like the most car engines in the world now are (Europe, Far East) it can make a big difference with the octane. If the engine is made to use high octane you will see a drop in fuel mileage if you run low octane gas. You will also feel lack of power.
If the engine is designed to run 87 like most U.S. cars at least used to be you will not see gas mileage improvement if you run high octane gas. This is simply because the engine was not designed for it. It is waste of money to use high octane fuel on a car that was designed to run with low octane.
And another fact is that all gas regardless of octane rating has the same amount of energy in it. Hig octane does not have more energy than low octane. It is all about how the engine behaves with it.
Most or perhaps all Japanese (or Far East) cars advertice that they run 87 octane fuel. This is because they can use it and they understand that people around will pick the car that can be run with it. If they would fill up with the premium fuel they would feel power increase and without themselves knowing would also get better fuel mileage, which would offset the higher price at the pump.
The engine does not know where it is, i.e. if it in the mountains or not. The sensors measure and adjust things like fuel injection accordingly. With low octane fuel high compression engine cannot take as much fuel in as it would pre-detonate. This means that a cylinder cannot produce the same "kick" as with the high octane fuel. This also means the efficiency from the cylinder goes down, i.e. you miss some forward movement from the fuel you burn. With high octane fuel the cylinder can take the maximum amount of air and fuel for maximum compression for the maximum "kick" for the maximum power and gas mileage.
Correct - and that is why I noted a significan decrease in gas mileage when driving uphill in the mountains. Also the same reason that my BMW fine on 85 octane on those 20,000 miles across Kansas that was as flat as a pancake - there the engine had to do very little to keep the car moving forward at 70mph.
Old 08-01-2012, 07:39 AM
  #53
CEB
CEB's Avatar
mmmmmmm, bacon...
Old 08-01-2012, 08:58 PM
  #54
brauhaus313's Avatar
asdas
Originally Posted by mnje350
Not quite. I was referring to last sentence of your prior thread. Clearly an expression of your opinion.
Based on the title of the OP, "What fuel do you use?", it would suggest anecdotal information, opinions and facts are all welcome. If he had asked ,"What fuel should I use", your rant would be appropriate. So lighten up.
Oh, based on the title huh? I don't need to lighten up, life is good. You ought to, since your panties are still in a bind.
Old 08-01-2012, 09:54 PM
  #55
mnje350's Avatar
2010 E350, 2015 S550
Clearly your opinion, again!! See, it's all part of the fun. Now all you have to do is contribute something interesting without a snide comment.
Old 08-01-2012, 10:04 PM
  #56
K-A
K-A's Avatar
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Don't mind Brauhous, his life's clearly got him bitter as snide comments are pretty much par for the course there.
Old 08-01-2012, 10:11 PM
  #57
mnje350's Avatar
I have started to notice that.
Old 08-01-2012, 11:12 PM
  #58
K-A
K-A's Avatar
Indeed. Though, for the record I might be confusing him with someone else, pretty sure I've got the right screen name though.
Quick Reply: What fuel do you use??
