What speed gives the highest mpg?
My question is: What W212 speed gives the highest mpg on the mpg bar graph? Of course, that's assuming nearly flat terrain with minimal head or tail wind.
Thanks.
I contribute this to having 7 speed wonderful tranny and massive torque to the car
Obviously you have to keep up with traffic, so if the speed limit is 55 MPH, then go 55 MPH but from a fuel economy point of view, you'd most likely get better fuel economy at 50 or 45.
They do have some other tips on the site, but the one I really have proven is using cruise control. it also helps prevent speeding tickets.
The bar graph on my 2010 maxs out at 40 MPG, does yours? Also noted that when I reset the other MPG gauges, they start at about 22 MPG no matter if I am going down hill with foot off accelerator. My previous cars with MPG gauges would show 99 MPG going downhill with foot off accelerator.
BTW, my best MPG is to leave it in the garage and drive my wife's 4 cylinder RAV4.
For posting your Fuelly.
I think that you will (and have already) discovered that you do better
fuel economy wise when going faster than 45 or 50 mph.
If I had your approximately higher by ten (10) percent gearing in mine, I think my 'sweet-spot'
would be at 65 mph instead of 60 mph where it seems to be now.
At a true 60 mph, mine turns exactly 1772 rpms. What's yours?
My max. torque is supposed to be between 1800 and 2400 rpms.
DHG
On getting better mileage, over the past 43000 miles, I've been getting 20-27 MPG, the lower in all-city driving and the higher on long, high-speed (80 MPH on cruise) runs to Disneyland. On average I get ~22.8 MPG all around with my E350 in [C] mode and using cruise whenever I can.
Oh, and Rock 'n Roll music makes me drive faster, but funner ... anyone else's music have an affect on their gas pedal usage?
.as for music, music really affects the way i drive. hip hop makes me drive a bit more aggressive
. jazz/blue, in a more relax way
The newer Bluetec Diesels do not do as well Fuel Economy wise as the older model diesels.
The differences in the E-350 gasser and the diesel EPA ratings is only one (1) mpg!
But that's progress I guess. Blame it on the tougher smog laws and the heavier E-Class sedans.
One wonders how the S-Class diesel sedans get the same EPA ratings as
the E-Class diesel sedans and the S-Class is all wheel drive to boot.
Something is fishy!
I do not believe that they do.
DHG
All you need to do is to view the results on Fuelly for the W-212 diesels.
They do not an can not get the fuel economy the 2005-2006 W-211 CDIs achieve.
Why? Mainly because the W-212s are not only at least three hundred pounds heavier
but they are wider also and have larger and heavier wheels with run-flats.
Also, because they are heavier, the engineers saw fit to gear them lower which means
they rev higher at any given speed in spite of their seven speed transmission.
DHG
MPG figures are good for comparing one model to another or to other makes, but not for determining what you are going to get. In effect, a car rated at 40 MPG should get 5 MPG over one rated at 35 MPG, depending upon how you drive, how much junk is in your trunk, etc.
My older CDI was rated (when new) by the EPA at 27 mpg city and 37 mpg highway.
The newer revised' EPA rating for the CDIs is lower at 25 city and 35 highway.
I can and do regularly get tank mileages better than the newer 'revised' ratings.
These tank mileage average figures include some city as well as mostly highway driving usually
over a period of several days with many cold starts and usually include a lot of A/C useage.
We like to ride 'in comfort' don't you know!
All you need to do is go to my Fuelly postings and see for yourselves.
I say again, these newer V6 3.0L Bluetecs, even though their engines are smaller and these later
cars do have the advantage of their seven speed transmissions, do not and will not get the fuel
economy that the older (on this continent) 2005-2006 CDI 3.222L diesels can and do achieve!
To prove my point, read my Fuelly and study what the newer model owners are reporting.
It is all there in black and white by individual owners.
DHG
This as reported by the on board computer with AC running. Not a clue what the mileage would be at a something lower.
I was impressed with high 20's for this car. Gasoline 2010 E350.
While your onboard computer is somewhat better than a guess, that's about all it really is.
I find that mine will show as high as forty (40) miles per gallon for the entire tank, but when I use my calculator and divide
the miles driven by the gallons used to fill the tank up to the brim, the computer can be off by as much as five (5) MPG.
With my CDI, I have seen computer readings over several hundred miles on a long trip
as high as 43 mpg, but when I fill the tank, it will figure out to only 37 mpg.
That is how far off some onboard computers can be.
By the way . . . with the fuel economy I am getting regularly, I am not complaining!
DHG
