Sponsored by: CARiD
Tire Pressure Warning Light
Old Sep 13, 2012 | 09:51 AM
Gravitas's Avatar
E350
I have a 2012 E350 Sport. My pressure warning light is RELENTLESS. I understand the importance of this safety feature but is this an indication of a true problem? I've been to the MB dealer twice about this, but if the car is running absolutely fine, the pressure is off because of the weather(???), is it necessary that I have to drive around with a warning light on all the time? Short of my buying an air pump and keeping it in my garage, does anyone have a solution? Thanks.
Old Sep 13, 2012 | 10:21 AM
norcal_cyclist's Avatar
2010 E350
If it's always the same tire you have a leak...
Old Sep 13, 2012 | 12:48 PM
W210's Avatar
2000 W210 E55->2003 R230 SL500->2004 W211 E55->2007 997TT+2007 E63->2010 GLK350->2012 E550 4matic
The US and Canadian cars are different aren't they? Don't recall the tire pressure warning light.
Old Sep 13, 2012 | 12:55 PM
ghstudio's Avatar
Mercedes e350 BlueTec
Somewhere in the settings for the tire pressure setting display between the speedometer and tachometer there is a way to reset the point where the tire pressure alert goes on. Yours is probably set much too high (as mine was). I forget where it was, but if you hunt around using the buttons on the steering wheel, you'll find it.
Old Sep 13, 2012 | 01:27 PM
BenzV12's Avatar
W212 FL
Hey,
This is a video for you to learn how to reset TMPS
BTW, I see such a warning message regarding tire pressures but not that symbol between 6 and 7 K RPM
I added some air today at the left rear tire , do not ignore such messages
Old Sep 13, 2012 | 03:09 PM
Gravitas's Avatar
E350
Awesome advice guys. What I will probably do is get a nice compressor with a gauge. Thanks again!
Old Sep 13, 2012 | 04:09 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
In Operator's Manual
There is a section in the Operator's Manual on the TPMS indicators and warning lights and how to set the TP level.
The only time mine came on is the first time they rotated the tires (Luxury model) and the tech forgot to adjust the tires.
Bottom line, once you set the TPMS levels, it should never come on unless you have a problem. Not sure, but I think they have to be about 10 lbs. low for warning light to come on.
