Sponsored by: CARiD
dropped a dime in the cig lighter
Old Sep 29, 2012 | 10:11 PM
vdubpower's Avatar
i drive them all, fast and hard
so yeah accidently dropped a coin in there, and now it doesnt work, anyone know if its just a simple fuse swap or what? thanks
Old Sep 29, 2012 | 10:22 PM
Tomspo04's Avatar
2017 CLS550, 2016 HD Roadglide (120ST), 1972 Super Beetle
I would guess that you blew the fuse. The cig lighter works by shorting positive to negative through a coil. When you dropped your dime it provided a direct short and blew the fuse.
Old Sep 29, 2012 | 10:44 PM
Darbyva's Avatar
2012 E350
Yep. I had a penny in the lighter socket in my old car. Changed the fuse 3 times before I figured out the problem.
Old Sep 29, 2012 | 10:59 PM
xolinlevh's Avatar
2011 E550 4Matic
Maybe its a sign to quit smoking? :P
Old Sep 29, 2012 | 11:42 PM
vdubpower's Avatar
radar detector bro
Old Sep 30, 2012 | 11:48 AM
xolinlevh's Avatar
2011 E550 4Matic
Ah. Been wanting to get one of those
Old Sep 30, 2012 | 12:47 PM
hyperion667's Avatar
2012 CLS63
hardwire that thing lol
Old Sep 30, 2012 | 02:01 PM
listerone's Avatar
2018 BMW 540d
Simple fuse replacement (and removal of dime) is my daignosis.
Old Sep 30, 2012 | 02:04 PM
Nuru's Avatar
S350 BT 4MATIC
1) remove dime
2) make sure one has multiple fuses
3) change fuse
Old Sep 30, 2012 | 02:17 PM
vdubpower's Avatar
gotta go find the manual and see where they hide the fuses for this thing...
it hasnt seemed to affect anything else, so maybe this fuse is isolated to the cig lighter
Old Sep 30, 2012 | 02:29 PM
WDLUGITCH's Avatar
2003 C240
I wonder what a dealer would charge to remove you dime and replace your fuse.
Old Sep 30, 2012 | 02:34 PM
Nuru's Avatar
S350 BT 4MATIC
does the manual (owners), have a map of the SAM Module fuses?
Old Sep 30, 2012 | 04:33 PM
W210's Avatar
2000 W210 E55->2003 R230 SL500->2004 W211 E55->2007 997TT+2007 E63->2010 GLK350->2012 E550 4matic
Wanted to hardwire mine, ended up running a long phone cord from trunk's lighter outlet all the way to the driver visor!
Has anyone used V1's new Savvy? Seems to eliminate the lighter requirement as it plugs directly into the car's ODB.
Old Sep 30, 2012 | 04:35 PM
2012 CLS63
have not tried the savvy........have both of my V1's hardwired in
Old Sep 30, 2012 | 04:54 PM
Live Oak's Avatar
E550
$199.90. The dealer keeps the dime.
Old Sep 30, 2012 | 06:56 PM
WDLUGITCH's Avatar
2003 C240
As frightening as that number is, you are probably low.
Old Sep 30, 2012 | 07:03 PM
vdubpower's Avatar
dime is out, maybe i can just get it covered under warrenty, need first oil change soon anyways,
Old Sep 30, 2012 | 07:12 PM
2 '02 S600's Avatar
2020 E63S4S
Based on owner's manual, fuse box in engine compartment & one in the trunk area. I would think somewhere in the trunk fuse box would be cigarette fuse, but who knows.
Old Sep 30, 2012 | 08:41 PM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
I have done it more than once. The dealer will replace the fuse for free.
After that remember where the fuse is. The spares fuses are with the spare tire kit.
Old Oct 1, 2012 | 01:59 PM
xolinlevh's Avatar
2011 E550 4Matic
Random Q for those of you with detectors, im looking at getting one but not sure how nice they play with Distronic+, can you use both?
Old Oct 1, 2012 | 02:23 PM
W210's Avatar
Distronic+ interferes with K band, I have my V1 K band turned off for that reason.
There are other threads on this, I understand unless you do a custom installation buying a bypass module from Midcity combined with certain model of Passport detectors, we are out of luck?
Old Oct 1, 2012 | 02:36 PM
xolinlevh's Avatar
2011 E550 4Matic
Gotcha, i dont know much about radar detectors, whats the K band?
Old Oct 1, 2012 | 04:53 PM
Arrie's Avatar
I have the Escort 9500 ix and it does not interfere with my Distronic Plus.
Very seldom I get K-band alarm like when I have parked my car facing a wall and at start-up it sometimes gives a couple of beeps but other than taht no problem at all, which then leads to my question if the detector is working ok?
I do get K-band alarms on road and then there is a cop or in most cases a digital speed display at the side of the road.
Ka-Band, which is most common in cop cars alarms way out if they have it on. This one works very well.
Old Oct 1, 2012 | 05:00 PM
Karl901's Avatar
With the 9500 CI Escort, you need to has a additional black box installed for the laser jammer to work with distronic . Check with mfgs.
Old Oct 1, 2012 | 05:53 PM
listerone's Avatar
2018 BMW 540d
Did you know that there a chart of all fuse locations,fuse numbers and functions of each one? It's where the spare tire is...or would be if your vehicle doesn't have one.
