are motor mounts cover under warranty?
my w212 2010 warranty is about to expire in another 2k. i started feeling bad vibration and notice that when i rev the engine it lean up in the driver side. i believe is a bad motor mount. Will the warranty cover this?
unless it's normal wear and tear, everything else should be under warranty and you should make an appointment as soon as you can. that 2k miles won't last too long.
