Winter tire pressure.
2011 E550 4Matic
So now that its getting really cold out, every time i start the car i get the warning that my tire pressure is low (fronts 26 rear 29). I know that when its cold the air contracts and lowers the pressure, which can make the readings flux. So Im curious what i should be aiming for in the winter, if on a cold start its at 26 is that ok? it will expand as i drive or should i go over-fill the tires to compensate for the cold?
1 Post
2014 E350, 2012 SL550
Regards,
Don
I've always assumed that recommended tire pressures were the same year round.Once a month I adjust tire pressure and in winter I put an extra pound or so in anticipation of colder than expected temps.
My advice. It's free, so consider that.
Get a very good tire gauge. If you can, compare it to a friend's quality gauge to be sure it's within a pound or so. Spend a few bucks on a cigarette lighter plug-in compressor. No more crappy gas station air for a price!
Set your tires as specified on the gas filler door. Then set the TPMS. It will read differently from your tire gauge, but your gauge is almost certainly more correct. Use the TPMS as a warning device -- if a tire goes downhill, TPMS will tell you.
Periodically check and reset your tires using your gauge, especially when cold weather sets in. In normal weather, expect to lose about a pound a month,
E350 4Matic 2011
A rule of thumb from the Tirerack says 1 psi change for every 10 degrees Fahrenheit.
On my 09 c300 4Matic (r.I.p due to hurricane Irene) it said on the gas cap add 5psi in cold weather. I believe the c300 was 30 on front 35 in back (or visa versa) so in the winter I added 5psi to each tire. Not sure with my 11 e class I only had it a week... Hope this helps
Received 3,399 Likes
2012 CLS63
You should use the pressure just the same way as in summer time. If you start with low pressures the tires will heat up quite a lot while you drive and the pressure will increase but if you have the correct pressure at the start of the drive they will not heat nearly as much. You don't over fill the tires if you use the correct cold pressures.
Yes!!
Nitrogen is used in airplane tires, for good reason. No oxygen means less deterioration in those special tires and wheels, that typically spend a lot of idle time sitting outdoors. And nitrogen leaks off a little bit more slowly.
Most important, a low tire on landing can put you upside down on a taxiway!!
But for a car??? No reason for it, except for the pretty green valve cap, a sense of gas superiority, and the need to line the coffers of the nitrogen supplier, especially if it's your dealer who didn't make enough money when he sold you the car.
E350 4Matic 2011
Yes!!
For a car, I have heard mechanics on some car TV shows explain that the nitrogen fill is beneficial when you have tire pressure monitoring hardware inside the wheel. The reason is that the nitrogen source should not have any moisture in it which can corrode the TPMS hardware over time.
2012 CLS63
Yes!!
2010 E350 Luxury Sedan, Engine 272 (V6)
My car calls for 30 front and 35 rear for normal, but I run 32 and 37. The Operator's Manual and fuel filler door label also have a higher TP, but that is for heavy loading, etc.
I check mine with a gauge about every two months and use a hand pump to add air if needed.
TP should be same at all times, regardless of weather or temps. Of course, they are going to go up when you are driving, especially on long trips.
I exclusively only use 78% Nitrogen in my cars.
I believe the tire pressure should be the same in the winter and summer or otherwise on the little placard they'd list seasonal pressure figures, which they don't.
