Sponsored by: CARiD
Will these SL R231 wheels fit
Old Dec 14, 2012 | 05:35 PM
tim175's Avatar
W212
Hi all,
I'm looking for some of your expertise in wheels and offset.
I'm interested in buying some AMG wheels from an SL R231 in 19".
Front: 8.5J ET35,5 - 255/35 R19
Rear: 9,5J ET48 - 285/30 R19
http://www.alloywheelsdirect.net/mer...oke_wheel_3292
Will these fit without rubbing or coming beyond the fenders?
My car is a 2010 350 with sports package.
THanks!
Old Dec 17, 2012 | 03:44 AM
tim175's Avatar
W212
Anyone?
Old Dec 17, 2012 | 05:13 AM
bigigg's Avatar
14' CLS550
They will fit, if you change your tire size.. i'd go with 245/35 front and 275/30 rear.
Old Dec 17, 2012 | 08:55 AM
threeMBs's Avatar
Only MBs - the best or nothing
Wheels with tires should fit without any changes - front will be flush with fender, while rear will be "in". Worst case scenario - 3mm or 5mm flat spacers maybe required at the back if any inside rubbing occurs. Personally, I would use 10mm rear spacers (with 10mm longer than stock bolts) from the start for a flush rear fitment to match front.
Old Dec 17, 2012 | 12:58 PM
bigigg's Avatar
14' CLS550
If you keep the 255 front, don't lower the car. You will rub.
Old Jan 26, 2013 | 04:43 PM
tim175's Avatar
W212
Thanks guys for your answers, maybe in the future I will lower my car.
At stock height, I won't have rubbing problems?
I'm still affraid of rubbing issues when passing a speed bump on the front tires. (255)
