Et37front Et39rear too aggressive?
http://www.usarim.com/19-mercedes-benz-cl-clk-ml-sl-amg-gunmetal-wheels-rims-p-1961.html?osCsid=98o3keeeojai9vjtvid1os2uu5
Yes. 9" wide rim is an industry standard measuring width for 255/35 size. The tire itself can be mounted on 8.5-10.0 range wide wheel.
The reason I posted those tire sizes is because I have them on both my Es on identical width wheels as above - no issues. As a side note: car can even take a 265 width tire (but on 9" wide wheel with a perfect offset) upfront with no clearance issues when non-lowered.
14' CLS550
If you plan on lowering the car, consider 245/275. Also consider the look if your going for a more flush with rim/no bulge. Not trying to confuse you anymore.
