Sponsored by: CARiD
squeaky belts?!
Old Feb 2, 2013 | 02:43 PM
chrisvr6's Avatar
lexus gx470
squeaky belts?!
Anyone else's doing it on first startup in the morning?
Old Feb 2, 2013 | 04:23 PM
dtohio's Avatar
05,cl65;33ford3wc.
Don't have an answer, but I think some small amount of slipping is normal due to start up charging needs, and the cold belt probably doesn't grip as well as a warm one.
Old Feb 2, 2013 | 05:33 PM
Nuru's Avatar
S350 BT 4MATIC
I had this same/a similar issue and they (Service Techs) initially sprayed some fluid on the belts to stop the noise. It went away for a while, then it came back. The next time they replaced a pulley. they indicated that this was something they were familiar with on the E350s. So it could be the belts, or a pulley. There should not be any loud squeaky/whistling noises coming from the front of the engine.
Old Feb 11, 2013 | 06:12 AM
titanium681's Avatar
2007 cls550
I have the same problem on my CLS550. I'll spray it, and it goes away for a few days and show up again. I will be replacing the idler pulley this week, as soon as I figure out how to release the tensioner pulley. The idler pulley was only $30.
Old Feb 11, 2013 | 07:47 AM
hyperion667's Avatar
2012 CLS63
nope, my seat belts work jut fine
Old Feb 11, 2013 | 11:26 AM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
Belt dressing is very temporary. A longer lasting alternatice is a bar of soap. I prefer good old fashion Ivory soap. Carefully apply the bar to the gripping surface of the belt while the engine is spinning. This will quiet it up. If it is a misaligned pulley or bad bearing, it will come back relatively quickly.
Old Feb 11, 2013 | 06:20 PM
bob2011's Avatar
2011 E550
Mine does it in the morning, when i first start it up. :/
Old Feb 11, 2013 | 06:52 PM
chrisvr6's Avatar
lexus gx470
Now my lexus (93kmiles) doing it. Guess its contagious.
Old Jan 9, 2016 | 08:36 AM
jerome8283's Avatar
GLS450
I know this is an older thread but my 2010 E350 does this sometimes. It seems to occur on colder days on startup in the morning. What is the fix and cost? My warranty is expired.
Old Jan 9, 2016 | 10:13 AM
dtohio's Avatar
05,cl65;33ford3wc.
Maybe a new belt and tensioner is the answer. When I have read the mfg. fact sites they say the poly v belts wear their grip surfaces so a change can take place on a good looking belt.
dick.
Old Jan 11, 2016 | 09:17 AM
dbldpr's Avatar
Veteran: Navy
Found out a long time ago to just replace the belts when they start to squeak. The sprays and soap are only temporary fixes. It just comes back.
Old Jan 11, 2016 | 10:05 AM
jerome8283's Avatar
GLS450
Shouldn't belts be changed during one of the scheduled Services? Does anyone know which service?
Old Jan 11, 2016 | 10:29 AM
dbldpr's Avatar
Veteran: Navy
I do not believe that it is part of any scheduled maintenance. Usually they get changed when they become cracked or squeak.
Old Jan 11, 2016 | 11:16 AM
bachree's Avatar
2010 e350 Luxury p2
2010 E350 maintenance manual only mentions about belt inspection. there is no change schedule. Not sure about other models. My car is at 38000 miles and i've heard belt squeaking for the first time when i cranked it in the morning when it was 20 degrees and the car sat outside over night. Other than that never heard it squeak. Not sure if it was pulley or the belt.
