Interior Trim issue/warranty question
Recently picked up a CPO 2010 E550 and noticed a small issue with the center console "flap" on the drivers side after taking the car home. It's small, but it's more than enough to make bug me and make this thread. Anyway, the adhesive seems to be failing and the leather is separating from the padding right where the cover contours toward the center in the front. Would be hard to get a picture of it, but you can clearly see it's there. Also, that same "flap" has some bad hinge action, squeaking when opening and getting stuck about half way open. Does it work? Yes. However, I still have some factory warranty left and was curious as to whether this would be covered, was it common, and is it worth getting fixed?
