Sponsored by: CARiD
Rear deck rattle
Old May 19, 2017 | 03:08 PM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
Originally Posted by fintail
I think my issue was the plastics on the rear deck - it would make noise even when the car was stopped and not running. My theory is that direct sunlight made the plastic expand, and occasionally pop. In cold or dark weather it never happened, but once the sun came out, there it was. The dealership improved it a bit with felt and lubrication. I no longer have the car, but I notice it a little in my current 2016 car. I think it is a design flaw. I've never heard the legendary pano noise.
Thanks---while my car was in, I told my SA to felt the back shelf area...we'll see if there is an improvement when I pick it up tomorrow.
Old May 21, 2017 | 08:19 PM
fintail's Avatar
S213 E450 4Matic, W111 220SE - prior cars: 3x W212, W210 E55 AMG, W202 C43 AMG, W126 300SE
Good luck. Mine was not cured, but it was a lot less noticeable.
The 16 seems to do it a lot less, but still makes a little noise back there. Maybe I am used to it. I can go over train tracks without a sound from back there, but sitting in the sun will make it pop. I hope the 213 has different design.
Old Apr 4, 2022 | 02:58 AM
Roma's Avatar
2014 E350 4Matic
I have a very similar pain as most of you guys have experienced, I have tried to use foam, Velcro and still didn't help much. Once I remove shell speaker cover panel it sounds great, I can't complain. My question is do I need to replace the shelf speaker trim or I have to do something else. All comments are greatly appreciated !!
Old Apr 4, 2022 | 03:01 AM
Roma's Avatar
2014 E350 4Matic
Did it fix your problem by replacing shelf trim cover panel or you had to do something else ?
