Sponsored by: CARiD
Question about sound system
Old Apr 10, 2013 | 04:12 PM
crazee's Avatar
E350
Hey guys,
First post here, with hopefully a simple question.
Is there a way to change the default volumn setting on my sound system?
I have a 2011 E350 Bluetech that brings the radio on louder than I would like everytime I start it up. Turning it down before I shut off the car changes nothing.
Sorry if this is in the owners manual. I haven't read a book that thick since high school!
Steve
Old Apr 10, 2013 | 08:53 PM
hyperion667's Avatar
2012 CLS63
Talking worthless post
welcome to the forums Steve,
that's an odd symptom to have eh?
I think many folks had the opposite concern, but it sounds like something the
dealer might be able to adjust.....
mine has never been too loud upon start up, usually where I leave the volume....
good luck and enjoy the ride
Old Apr 10, 2013 | 10:26 PM
ttoE550's Avatar
2015 GL450
You might do a search, as I think there was a previous thread on this same topic. The funny thing is that mine is always where I left it. There is no default level. If I can barely hear it when I turn it off, I can barely hear it when I return. Or if it's blasting, it will still be blasting.
I assume you are compensating for the fact that most times the music will SEEM louder when you return to the car since it's a new sound and not one you've been listening to for a while.
Old Apr 11, 2013 | 03:00 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Originally Posted by crazee
Hey guys,
Steve
I HATED that about my E's. Very crude, un-luxurious vibe it gave with the intrusively high volume when I got in. It plagued both W212's I had. I'd automatically be used to lowering the volume every time I got in.
I made a thread about it an can't remember if it was ever resolved with anyone, but not on my cars. Some people said they didn't have (or notice) the same issue, however. You can read through it:
.... Edit: Can't find the thread I thought I made about this. I know I made a fuss about it an a discussion ensued. Maybe it was on one of the DTB threads or something.
Old Apr 11, 2013 | 04:59 AM
BenzV12's Avatar
W212 FL
Welcome ,
I believe this should be sorted out thru Engineering Menu , I am also doing same thing each time I start the engine
Old Apr 13, 2013 | 10:46 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
I never experienced this with either my E or my S. The volume is always right where I left it. Strange. There must be a setting somewhere that gets yacked up from time to time.
Old Apr 15, 2013 | 09:35 PM
telemakhos's Avatar
E350 4Matic 2011
Me too. On my current E and my previous one. The volume stays just where I leave it.
Old Apr 16, 2013 | 08:44 AM
mbuster25's Avatar
2010 E350 Luxury 4Matic
My volume also stays where I leave it, but I wish there was a numerical indicator as to volume level
Old Apr 16, 2013 | 02:47 PM
chrisvr6's Avatar
lexus gx470
Mine is louder too.
Old Aug 12, 2018 | 01:48 PM
captearlg's Avatar
05 S600
My 2005 S600 just started to raise the volume level when I just start the engine.
It is way louder than normal. Did anyone ever find a solution to this problem?
Old Aug 12, 2018 | 02:28 PM
2012 CLS63
Old Aug 12, 2018 | 02:43 PM
Alandf's Avatar
2016 E350 Sedan
Totally annoying. Every time I start the car I have to turn the radio off ,even if it was off before last shut down. ( I also hit the eco button at every start
Old Aug 12, 2018 | 05:27 PM
Arrie's Avatar
does your car save radio station or other audio source with the memory seat setting. If it does it may also save the volume level meaning that what ever volume level you had at the time you saved the seat position it could be picking that same level every time you start the car.
Old Aug 13, 2018 | 04:40 AM
Alandf's Avatar
2016 E350 Sedan
Tried your suggestion.Did not work on my car. Radio comes back on at its' last volume setting.
Thanks for the attempt
Old Aug 13, 2018 | 07:43 AM
DFWdude's Avatar
2016 E350 Sport
Readjust the settings for Bass/Treble, etc, at the volume you want, then see if the saved settings also correct the volume level.
With my 2001, very occasionally the volume will randomly spike on start-up. That car has a EQ reset button (to factory settings), However, readjusting the preferred levels always solved any issues. Again, it doesn't happen often. Haven't found the reset for the W212 yet as I haven't needed it. But I wager there is one somewhere.
