New 2013 E350 gas pedal vibration
Hello, my name is Richie and i just pulled a brand new E350 off the lot a week ago and i am experiencing a minor vibration on the gas pedal. This vibration only happens when i start up the car after it sits for a couple of hours. I would put it on drive and lightly step on the gas pedal to accelerate. But it only vibrates for a second. Is this normal?
2012 S350 Bluetec 4Matic, Diamond White, P2
There must be something loose. There is no mechanical connection of the pedal to the throttle. It is all fly-by-wire. Does this vibration happen in the brake pedal also? I would have the deal take a look asap.
Think of the throttle assembly as a big switch, with only a couple of bolts holding it to the floor. You can reach down and feel if tho bolts are loose, but I doubt it for such a limited-time effect as you describe.
Drop by the dealer and have your SA or service manager go for a drive. They should be able to fix that right up.
