No Bluetooth Music Streaming?
Posted from Mbworld.org App for Android
Basically , NTG 4 by default don't support Bluetooth Audio it needs some tweaks
Turn on BT Audio in the engineering menu, then took it to the dealer for the COMMAND update. If there is a diagnosable and repeatable problem, there shouldn't be any trouble getting service. Some dealers are easier than others.
The problem is as BenzV12 mentioned, the NTG 4.0 didn't have it turned on by default and the programming just wasn't all the way functional. It will work depending on how loosely you use the term "work." For me, it only worked when using external authorization to pair the BT device every time I started the car, and by using it, you disable phone integration. So you must choose phone service, or BT audio service. The COMMAND update fixes those problems, works perfectly.
