Antenna Removal
Antenna Removal
I am trying to remove the antenna on my 2010 E350. The rear headliner has an access panel that is easily removed. I was then able to remove the one torx bit that holds the antenna to the roof. The problem is there are 3 wires going into the antenna. There seems to be no provision to disconnect the wires from the car. I do seem some screws on the bottom of the antenna but don't have enough slack in the wires to access them.
Has anyone removed their antenna
Thanks, Ron
Update
I was able to get enough slack in the wires to remove the screws from the bottom of the antenna
I removed the screws and the Top of the antennaccame off. The only thing I see are some circuit boards with no way to remove the wires.
So I am still unable to free the antenna from the car as there is no way to disconnect the wires going into it
Thanks, Ron
Update
I assume they plug connect at the other end.
