How do you copy MP3 from computer to COMMAND Music register?
I've got 4 or 5 GB of MP3's on my computer I'm trying to copy onto the music register in command. I've tried copying it to a 2gb SD. It can play from the SD but doesn't give me option to copy it to music register.
So manual says to copy the files to a CD/DVD then copy from the CD/DVD to music register, which I did, and it also plays fine but doesn't give me an option to copy to music register.
The only time I get an option to copy to music register is if I actually insert a regular music CD, then it gives me option to copy and takes a few minutes to copy the whole CD.
A lot of these MP3's I have on the computer don't have regular music CD's (purchased via amazon or google play), so how do I get these onto the command music register without having to convert and burn them to music cd first?
thanks
Does it have to be a hard drive and not a flash drive?
Amazon.com: SD HC Card Adapter Converter for Mercedes Benz PCMCIA Command System UP 16, 8, 4, 2, 32 GB: Computers & Accessories
This is, undoubtedly, a concession to the RIAA's obsession with piracy.
CD's with music in the form of CDA files can be copied to the car's hard drive.
It doesn't make sense, of course. The fact that you have a CD with CDA files on it doesn't mean it is an original, or that you bought it (it could be borrowed) so it could still be pirated.
The fact that you are trying to copy MP3 files doesn't mean the music is pirated. It could have been purchased legally at various online sites.
MB is just trying not to incur the litigeous wrath of the RIAA, IMHO.
Regards,
Don
With that said, since it takes forever to copy a whole CD to the music register, I don't even bother with it.
I live in Europe ! Sunny Spain.
I have the latest software installed on my 2014 model-year cars.
I have used a very high-speed 32GB USB stick.
Make sure it is formatted in FAT32.
I transferred the songs from iTunes on my iMac to the USB stick using Export for iTunes app (for sale on the Mac App Store) and Clean my Drive (also for sale on the Mac App Store), which have quite reasonable prices.
I had to to repeat the process many times until I got it right !
First, any songs with a slash in the name of the artists, song, or album will not be transferred...
Change the slash for a dash, for instance.Check for any Artwork, so that it does not exceed 1MB or it will be left blank.
You can resize it by using preview and storing it with reduced file size.
Select the playlist you want to copy.
Select the format Artist, Album, Song for the export in the app.
If you don't run Clean my Drive after you use Export for iTunes, you will find a 4kb file with a similar name for every song and the music register will foul up.
When you have the USB ready with the proper files, insert it and select music register. If you have music you want to overwrite, delete it first. You have an option to delete the whole register at once. Then select copy musical MP3 files, select USB stick, select all files, continue, start... In my case it took about ten minutes to copy 9GB of songs with 256kb bit rate, just over 1000 songs in apple lossless format.
Good luck and happy listening ! Hope this helps a few more people enjoy the Music Register.
For what it's worth, my manual states I can copy mp3, wma and aac. In reality, I can not!
The manual has always said it could be done but, in reality, it can be done only outside the US.
Regards,
Don
My MR has over 1,500 tracks or "songs" on it. These are in 171 folders. A folder is genrally one CD, but I actually combine CD's by same artists into single folders. So it is probably well over 200 CD's and some are double CD's.
You have to pick the destination folder before you start Recording to do this.
Still have room for more!
Takes about 20 minutes to download a CD. It may be playing a few songs, but is downloading the entire CD at same time.
Cautions: You can change or enter titles as you drive, one letter at a time. Can also select which tracks to record. Very unsafe and is ironic that MB lets you do this while vehicle is in motion.
Also, if Gracenotes does not recognize the CD, it will download it into a miscellaneous or some other folder. May end up with several CD's in this folder and have to open it and then open each one to see what they are. Best to give the folder a title. Also makes it easier to find what you are looking for later.
Happy Motoring!
Happy Motoring!
As I said earlier, I copy from a CD that was made on a computer or that I purchased. My most recent comment was re: how much can be downloaded and how long it takes per CD (about 20 mins.). Each CD I have downloaded has been anywhere from 30 mins. in length to 80 mins.
I do not believe it compresses the files, but I really don't know.
thanks
