I'm not sure if I'm the only one with this problem, or I'm doing it wrong but it has been a problem in my last 2 wagons.
When you have the rear seats folded with the cargo net extended to the roof from the back of the seats (directly behind driver), when you take a hard right turn, the base of the cargo net slides out of its brackets and it starts hanging free and swinging around.
How can I to stop this from happening??
Not sure about MB but I had a similar issue with Audi. I fixed it by adding a bit of electrical tape (I used the rough stuff, not the smooth tape) That gave it a bit more more grip and kept the pin from sliding out of the tube it fit into.Originally Posted by Mtl20v
I'm not sure if I'm the only one with this problem, or I'm doing it wrong but it has been a problem in my last 2 wagons.When you have the rear seats folded with the cargo net extended to the roof from the back of the seats (directly behind driver), when you take a hard right turn, the base of the cargo net slides out of its brackets and it starts hanging free and swinging around.
Thank you CEB..I'll give that a try.
Quote:
Please let us know how that worked.Originally Posted by Mtl20v
